Old 08-29-2007, 10:19 PM   #16
Send a message via AIM to beavis820
Default Re: How to: Pull your own motor
Originally Posted by Marceau View Post
THanks for the write-up!
I assume this is part of what an new cluth install looks like?
it could have been done this way, i dropped my trans to do my clutch but i think pulling the engine would be easier w/out a lift.
beavis820 is offline   Reply With Quote
Old 08-29-2007, 10:37 PM   #17
Nice write up. Thanks for sharing.
Pidro is offline   Reply With Quote
Old 08-29-2007, 10:40 PM   #18
Car: AW 06 STi
Fav Mod: Limited Spoiler
Send a message via AIM to SubyDoode
nice write up!
good info up there
SubyDoode is offline   Reply With Quote
Old 08-29-2007, 11:09 PM   #19
DCH
Fav Mod: Q-Rack!
Send a message via AIM to DCH
Pretty damn informative! Thank you!
DCH is offline   Reply With Quote
Old 08-31-2007, 08:04 AM   #20
Fav Mod: LS6 and T-56 swap :D
lol at messing up friend's garage I had to laugh outloud when I read the part about how you took the lightbulb from the garage
Anyway, informative DIY... although I don't think I'll do this myself when the time comes for a rebuild.
Rookie84 is offline   Reply With Quote
Old 09-20-2007, 06:30 PM   #21
Fav Mod: Ported Heads & Cams
Hey i was wondering i am pulling my motor as we speak.. Is there any special sequence to Removing the front 2 belts.. or do you just loosen up the tensioner and your fine?
STi_Guy04 is offline   Reply With Quote
Old 09-20-2007, 08:44 PM   #22
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
good write up. Almost exactly how I did my last one...
Side note, I bought that same grey/yellow handle screwdriver set a few weeks ago. How do you like it?
Old 09-24-2007, 04:04 AM   #23
sti_guy you may want to ask for help from someone with a little mechanic experience but will pm you.
screwdriver set is alright, it has a nice case that keeps all of them together but they arent very strong if your really cranking on them. i havent broke one yet but i will. but then again for less than $20 ill buy another set.
everyone else, thanks
Old 09-24-2007, 06:44 AM   #24
Car: 03 mbp gga
Fav Mod: 12.9 / 105+
Send a message via AIM to ride5000
imma gonna tell mike!
-ken
ride5000 is offline   Reply With Quote
Old 09-24-2007, 12:25 PM   #25
shhhhh
Old 10-07-2007, 04:08 PM   #26
Car: Silver 04 WRX STi
im pulling my motor as we speak and this has been a GREAT help... But i CAN NOT get the tranny to separate from the motor... HELP!!
nperkins is offline   Reply With Quote
Old 10-07-2007, 06:35 PM   #27
got it... when in doubt... Get a bigger hammer.... Took UNBELIEVEABLE forceto get it out... wow... Spraying some lubricant around the seam helped too...
Old 10-08-2007, 03:34 AM   #28
be carefull with that lube if your reusing your clutch. and sometimes its easier if you have someone under the car because you can get a prybar between the engine/trans under there(ive never had to do this)
Old 10-08-2007, 04:26 AM   #29
lol... reuse the clutch... Thats a good one... Do you have a way to glue fibers back onto the disk? Or remove the metal shine from the disc? I'll post pics of the clutch later on for you.. Exedy 3 puck FTW...
Old 10-08-2007, 07:23 AM   #30
okay... Now I cant get the Cam Gears off... With the timing belt still on, its trying to jump timing... and i dont know anybody with a Camshaft Wrench... Im trying to make one, but there is nothing to bolt onto on the exh cam...
