Old 07-07-2007, 12:59 AM   #1
Car: 04 Subaru WRX STI
Angry Installing Stock Injectors. PLEASE HELP
I had my car tuned in denver at mac autosport this past weekend and they said that my injectors 1 and 2 are trashed. I got 4 used injectors and i put them in and my car wont start. I have no idea where to go from here.. The injectors are off of a 2005 sti and have an 04. When i first started it it turned over a few times and then a tonecame on and thats all that happend after the first few time i tried to start it. I tried disconnectinng all of them to make sure the connection was good and the i unplugged the fuel pump to see if that might do anything. Now im stuck in albuquerque until i can get this fixed and i have class on monday and theres no one who can take a look inbetween that time. I dont know anything about cars like you guys so if you guys know what the problem might be please give me some ideas. Thanks, Collin
Collin is offline   Reply With Quote
Old 07-07-2007, 10:46 PM   #2
Car: 04 subaru sti
Fav Mod: 35r turbo kit
Default Re: Installing Stock Injectors. PLEASE HELP
is your harness grounded out by anychance?
will12345 is offline   Reply With Quote
Old 07-08-2007, 12:39 AM   #3
everything that i had undone has been grounded back to the way it was before. where is the ground that your talking about and i have a feeling im missing something simple but im not sure what more i can try. i just pulled my spark plugs and a **** load of gas came out of two of the plugs. I replaced all of spark plugs and put all of the injectors in and then i tried to start it again and it did the same thing before. Its not even turning over and a mechanic thought that it was the starter but i dont see how it could be the starter if i was able to pull the plugs and clear out all the gas. I think my next step is going to be pulling the plugs and make sure they work. Like i said i dont know anything about cars so if you know anything that can help that would be great. Thanks alot.
Old 07-08-2007, 05:17 PM   #4
Car: 06 STi
Well you may have torn an injector O ring and its just loading your cylinders up with fuel. That makes sense because all the fuel is coming out of your cylinders when you take out your plug and then it wont crank. Liquid is will not compress therefore not allowing your car to turn over. Replace all your O rings, lube them up next time.
j87w is offline   Reply With Quote
Old 07-08-2007, 09:37 PM   #5
I put motor oil on them before i put them in is there something else i should have done?
Old 07-09-2007, 03:27 PM   #6
Car: 06 STi
Hmm.. not that I can think of right off the top of my head. I work at a hydraulic shop and I mess with O rings all day. The only thing I make sure to do is replace all O rings with new ones, lube them up with some type of lubricant, and when they go in make sure they dont catch anything that can tear them. Have you replaced the O rings yet?
Old 07-09-2007, 03:53 PM   #7
I didnt replace the o rings but i looked at them and they had no visibale damage. Im guessing the injectors i got are ****. i put the old ones back in and the car started but now it runs way bad. So now i need to order new injectors and hope that works. Do you know if i have to have my car retuned if i throw bigger injectors in or will i be ok? Thanks alot
Old 07-09-2007, 04:09 PM   #8
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
you will have to scale for larger injectors.
Old 07-09-2007, 04:40 PM   #9
Car: 06 STi
Fav Mod: Your Girlfriend Ridin Shotgun
Send a message via MSN to Inertia
We need to know why your injectors were out/replaced in the first place? Give us the whole story please.
Inertia is offline   Reply With Quote
Old 07-09-2007, 06:08 PM   #10
Car: 06 STi
Im willing to bet money if you replace your O rings and your injectors slide in correctly your car will run just fine. As long as the injector isnt stuck open then it should be just fine.
Old 07-15-2007, 03:35 PM   #11
Car: 07 STI
Fav Mod: V1
Send a message via Yahoo to npower
Try throwing in a new set of plugs for the drive home, if you loaded up the old ones that bad with gas, that could be part of the reason the car is running so bad now...aside from the 2 bad injectors. That is if it is worse then when you had the two bad injectors before hand.
npower is offline   Reply With Quote
Old 07-15-2007, 04:51 PM   #12
Car: 06 STi CGM
Fav Mod: what you cant see :-D
only one side went bad, ill have to agree with the others that either
1. you forgot to reattach the ground for the harness on that side
2. tore the o rings
thats a huge coincedence for both injectors to go out on just one side, so i am leaning towards option 1
srt42sti is offline   Reply With Quote
Old 04-12-2008, 11:44 PM   #13
Car: 02 WRX
If your in ABQ you could send your injectors to WitchHunter Performance - Injector Cleaning & Flow Testing Services and they will replace all the o-rings and clean and flowtest your injectors but your car is out 2-3 days but its only $75 just another thought
psico is offline   Reply With Quote
Old 04-15-2008, 06:45 PM   #14
Car: 05 WRB "STI"
Fav Mod: hugeee turboooO!
just replace both it might help!
STInoel18 is offline   Reply With Quote
