Old 07-05-2007, 11:37 AM   #1
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
Question Turbo inlet DELETE
Currently I am running the Perrin GT35R kit and I want to get rid of the turbo inlet hose all together since it is being pinched by one of the intercooler pipes. There are two oil lines that are on the inlet hose and i was wondering what I should do with them? The car is running speed density and I will cover the turbo inlet with a mesh fitting or something, but i just need to know what to do about the oil lines. If someone with tell me how to post pics on here i will... thanks for the help
B4RSTiwsnc is offline   Reply With Quote
Old 07-05-2007, 05:46 PM   #2
Default Re: Turbo inlet DELETE
Here are some pictures of my old rotated setup, I hope it helps a bit. I'm sure there are other people who can chime in on how they routed their lines but this is how I did mine.
The hose near the intake manifold is connected to a catch can but was just set aside for install purposes.
Ron
BLUE STINGER is offline   Reply With Quote
Old 07-06-2007, 07:13 AM   #3
did you throw any CEL's?
Old 07-08-2007, 12:16 AM   #4
No cel's that I was aware of.
Ron
Old 07-08-2007, 08:54 PM   #5
Fav Mod: GST Protune, less boost more power
Send a message via AIM to MorePSiTehBett4
what a setup, i wish i could have been around to ride in the beast with that turbo on
MorePSiTehBett4 is offline   Reply With Quote
Old 07-15-2007, 04:51 PM   #6
can i just cap the two on the inlet?
Old 07-18-2007, 09:17 PM   #7
Car: 2004 Subaru WRX STi
Send a message via AIM to Flynlow
Just replace the white T fitting with a straight thru fitting, that will eliminate the hose in the 2nd photo. You can get them from any automotive store.
Flynlow is offline   Reply With Quote
Old 07-19-2007, 04:49 AM   #8
Fav Mod: when it's not blown up
Those are your breather lines. With a 35r on the car you should definitely have a good air/oil separator or catch can. Do NOT plug those lines! (or remove the t-fitting, sheesh). I guess you could just leave em hanging, but they will make a mess of your engine bay... especially if you break a piston, it'll shoot oil everywhere.
Old 07-24-2007, 09:49 PM   #9
Yikes, I should have paid attention to this thread, but by all means don't plug up the lines. Jays05 is in the right track as far as addressing the breather lines.
Ron
Old 07-31-2007, 08:34 AM   #10
Car: 04 JBP STG II WRX
Fav Mod: 05 STI HID's FTW
Send a message via AIM to jupiterrex
nice kit... gl with the install
jupiterrex is offline   Reply With Quote
Old 07-31-2007, 09:30 AM   #11
Car: 04 subaru sti
Fav Mod: 35r turbo kit
yes do not plug any breather lines..to much pressure in the crank case will make your engine go BOOM!
will12345 is offline   Reply With Quote
