Old 06-27-2007, 10:05 AM   #1
Car: 2006 Aspen White STI
Fav Mod: Trading the WRX for an STI
Default Rear Differential Question
Hello,
I am planning to change my rear differential fluid (yes I've seen the how-tos; I will definitely use them when the time comes) but I am confused regarding the "bolts" for emptying and filling.
The only "bolt" I can see looks like a tilted SQUARE beneath the temperature sensor. Is this the part that comes off for the fluid to drain?
I have no idea what type of tool I would use to get this off (unless I'm looking at the wrong side).
Thanks for any help!
Shewillbemine is offline   Reply With Quote
Old 06-27-2007, 10:14 AM   #2
NIИja
Default Re: Rear Differential Question
It should be obvious which is to fill, and which is to drain. Thanks Wolfplayer for the pic.
Old 06-27-2007, 10:15 AM   #3
Thank you--but my question is how to get the bottom "bolt" out. It doesn't look like something I can handle with a wrench or socket--it's shaped like a square.
(Excellent pic btw--I've been struggling to look for one of those angles for a while)
Old 06-27-2007, 10:21 AM   #4
NIИja
What you need for a rear differential fluid change
Originally Posted by Singletrack
I pulled the bottom plug (1/2 drive breaker bar) and drained the fluid.
Meaning, you use the 1/2 breaker bar (a ratchet may work too) without a socket attatched (without a socket it will be a male square).
Old 06-27-2007, 10:28 AM   #5
Dude, you are awesome--it makes sense now!
Thank you sir--I love this site!
