Old 06-26-2007, 07:45 PM   #1
300
Car: 05 Subaru WRX Silver Sti
Fav Mod: Losing weight
Default HKS Hi-power CBE install?
I just bought a used (2 months) HKS Hi-power CBE and I need an installation manual. Is there a link some where? Or can someone tell how to install?? Ive looked at the HKS site but couldnt find any. Im new and still learning. Thanks in advance
300 is offline   Reply With Quote
Old 06-26-2007, 09:08 PM   #2
Car: 04 subaru sti
Fav Mod: 35r turbo kit
Default Re: HKS Hi-power CBE install?
all you do is undo the 2 bolts on the end of the downpipe, unhook all the rubber hangers, spray some wd40 in there if you need to, then put the hks midpipe on the end of the downpipe, put that one hanger on it, then put the hks axle back onto that and put the 3 other hangers on the hks exhaust and youre done
will12345 is offline   Reply With Quote
Old 06-26-2007, 09:48 PM   #3
300
Wow...short sweet and simple! me likes...oh wait...can I use the same nuts & bolts? Thanks for the input
Old 06-26-2007, 10:47 PM   #4
Car: 04 subaru sti
yes you have to use the front two spring bolts but the rear you should use new hardware and a 3 inch gasket
Old 06-26-2007, 10:50 PM   #5
Friendlys Suby
Fav Mod: M&J Modified
dont use wd40, it will be a mess. I would use windex or any window cleaner for lube.
Old 06-26-2007, 11:11 PM   #6
Car: 2006 Aspen White STi
wd-40 are messy? i thought they are pretty good too loosen up the bolts and stuff
cusco is offline   Reply With Quote
Old 06-27-2007, 12:02 AM   #7
Friendlys Suby
yes no doubt, but it will get all slippery and will have a tough time getting the hanger off. i was told this by tom from kartboy.
Old 06-27-2007, 06:04 AM   #8
Car: WRB 06 WRX STI
Fav Mod: Stage 2
If your on the stock DP, your gonna have a hard time compressing the bolt/spring set-up... took 2 people and some creative large plyer work to get the nuts back on. unless you want to just go with-out which is what you'll end up doing when you get an aftermarket DP anyways. As far as gaskets, I just needed one 3" 2 hole gasket for the midpipe/axleback connection.. the stock one worked for the DP/Mid connect.
SonicBoom is offline   Reply With Quote
Old 06-27-2007, 06:26 AM   #9
oMgWTFpewpew
Fav Mod: grip.
Send a message via AIM to chaos311clarity
pb Blaster or screwloose is the best penetrating lubricant ive found... either way this is a straight forward install and a good way to start off modding
Old 06-27-2007, 06:28 AM   #10
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
im sure searching will help you as well.
STI_Mike is offline   Reply With Quote
Old 06-27-2007, 07:59 AM   #11
Car: 06 WRB STi
Fav Mod: Greddy Ti-C
Send a message via AIM to reflexxi
pB Blaster worked like a charm for me during my CBE install.
reflexxi is offline   Reply With Quote
Old 06-27-2007, 08:52 AM   #12
Car: 04 subaru sti
thats the point of using wd40 so it is slippery, if youve ever tried getting a dried up hard rubber hanger off then youd see how handy wd40 is
Old 06-27-2007, 09:33 AM   #13
300
As far as gaskets go...any suggestions on the brand/type/material?? Ill need to get loc-tite as well for the nuts & bolts. oh another question, do I have/need to disconnect (-) the car battery (reset the ECU) when installing the exhaust?. With all this info in mind Ill be installing over the weekend! I hear its not hard, Ill take my time.
Old 06-27-2007, 10:02 AM   #14
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III >=)
i ended up buying longer bolts for the spring/bolt combo. worked like a charm.
SD 05 STi is offline   Reply With Quote
