Old 06-22-2007, 05:24 AM   #1
Car: '04 JBP STi
Fav Mod: Whiteline Steering Bushings
Default Replacing battery
Is it as easy as disconnecting the terminal and removing the tie down bar and pulling it out?
Im buying a battery today and have about a 10 min window to replace it when i get home from work
drdome99 is offline   Reply With Quote
Old 06-22-2007, 05:37 AM   #2
Car: 07 Subaru Satin Whit
Fav Mod: Protuned STG 2
Send a message via AIM to PCGuRu2K
Default Re: Replacing battery
Battery's about the easiest thing to change on our cars
Just remove the negative first, then the positive
PCGuRu2K is offline   Reply With Quote
Old 06-22-2007, 05:40 AM   #3
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
It's about as straight forward as it can get.
SoaReS is offline   Reply With Quote
Old 06-22-2007, 07:27 AM   #4
Car: 06 STI
Fav Mod: Prodrive oval tip
hardest part is actually lifting the battery out since they're lil heavy. like others said, neg off first and neg on last
