Old 12-16-2007, 04:42 PM   #61
Car: silver 04 wrx sti
Fav Mod: tic coilovers
Default Re: How-to Cure Bobblehead for cheap
On my 04 I did a quicky 3 square tubes running for and aft under those 2 perpendicular tubes, and pulled seat springs down with safety wire. sounds crude, yes, but I sit lower in seat and have great side support. I've been meaning to pull seat out and make a cleaner looking mod. of it, but have not found time yet. This was done 3 years ago, and no problems.
slidewaysteve is offline   Reply With Quote
Old 12-16-2007, 08:25 PM   #62
abracious
Fav Mod: Track time
post picts if you got 'em.
Old 12-18-2007, 09:30 PM   #63
After the holidays I'll make time to remove seat to make my mod. look a little more profess
ional and take some photos for you.
Old 12-26-2007, 12:14 PM   #64
subscribed
inlovewithb00st is offline   Reply With Quote
Old 01-01-2008, 03:40 PM   #65
help, I want to post my mod. photo, but I am in my 50's and semi computer literate. How do I post a photo with out a "Url"?????
Old 01-01-2008, 03:51 PM   #66
trying again with my nieces help.
Old 01-05-2008, 09:13 AM   #67
Car: 07 STI UGM
Fav Mod: Boob jobs
Oh that looks like a really good idea. It's rainny today so I think I'm going to give that a try.
Lurker is offline   Reply With Quote
Old 01-18-2008, 11:43 AM   #68
Fav Mod: CAR LIFT & Protune!
i will be trying this, i told my father to bring home some zip ties on the way home from work (for free). i was thinking lower in the seat is better. these seats suck ass.
Old 01-18-2008, 12:05 PM   #69
Car: PSM 04 WRX STi
Fav Mod: Cobb AccessPort
I now have a weekend project.
Ying is offline   Reply With Quote
Old 07-17-2008, 07:12 AM   #70
Fav Mod: Stage 1... Only mod so far
Another idea, what about running the zip ties above the springs in the same orientation as the black metal bars in this photo. Run the zip ties on top of the springs and around the perpendicular bars. Have someone sit in the seat to press the springs down, then tighten the zip ties to hold the springs down permanently???
trbolvr is online now   Reply With Quote
Old 07-17-2008, 07:31 AM   #71
abracious
Fav Mod: Track time
why not give it a try and report back?
Old 07-17-2008, 07:38 AM   #72
I was planning on doing it this weekend and I will report back.
Old 07-18-2008, 07:33 AM   #73
Well I took my seat out to look it over and was surprised to find out that my seat was already touching the springs with no one sitting in it.
So my idea of pulling the springs down wouldn't have made much of a difference. You can see on the left of the photo that the springs are already low enough that pulling them down would not of made a difference once someone is sitting in the seat.
This image shows that the limited seat is a bit harder to work with (after the pic I added a 3rd center strap).
This clearly shows that my seat is always touching the springs.
Old 07-18-2008, 07:34 AM   #74
abracious
Fav Mod: Track time
While I have yet to remove my seat, I am under the impression it is always touching the springs. The idea is to lower the springs so the seat can sage more (more bolstering) and bounce less.
Old 07-20-2008, 02:31 PM   #75
About a month ago I removed my square bars and put a piece of plywood below the front "U" shaped tube and the rear horizontal tube sercured to the tubes with mechanics wire running through holes drilled through wood. With the springs having been pulled down to the bars for a while, they've stetched a bit, so when I get in the seat the springs/cushion just touch the plywood. No more bouncing!
