Old 06-06-2007, 10:41 AM   #1
Car: Zero/Sports TA STi
Trader Rating: (16)
Send a message via AIM to edoperformance
Default Install Guide: ZERO/SPORTS Formula Pushbutton Starter Kit
Hello everybody!
Here at EDO Performance, we decided it was a good idea to show everyone how east it is to install some of our products.
So here for you today we have the first of many in a line of installation guides!
This one in particular is for the ZERO/SPORTS Formula Pushbutton Starter Kit. It turned out to be a very simple install that anyone could do themselves.
The Zero/Sports Formula Push Button Starter kit allows you to give your car that Formula-1 racing feel! The kit includes everything you need to install the starter button in your car.
Unlike some button starter kits, this kit requires NO soldering or splicing and simply plugs in between the factory wiring harness. For security, you will still need to have your key in the ignition before the car can be started with the button.
1. First of, like with any electrical install, you must remove power. This can be done by simply removing the negative battery cable.
2. Next, remove the philips screw underneath steering column cover. With a little moving, the lower half will pop off.
3. Remove 3 screws around lower dash panel. After these are out the panel will come out with a little tug (it is held in by a few pop-clips across the top).
4. Underneath and on the right side of the column you will see a 4-pin plug coming away from the ignition lock. On this 2002 WRX this plug was blue but it may be a different color on later years.
5. Unplug this connector and plug the Zero/Sports harness in between it.
6. Next you need to find a ground for the black wire coming off the harness box, I used the mounting bolt for the brake pedal above the firewall pass-through.
7. Mount the harness box somewhere under the dash. I just zip-tied the it to another box under the dash but it can be mounted anywhere you wish.
8. Connect the plug from the harness box the ignition harness.
9. Remove one of the blank switch plates from the dash panel and put the starter button in its place.
10. Connect the plug from the back of the button to the remaining plug from the harness box and reattach the lower dash panel.
11. Reattach the lower steering column cover.
12. Push the button and enjoy!
If you would like to request an install guide for any of the other products we carry please fee free to contact us!
-Kevin
AIM: EDO Kevin
edoperformance is offline   Reply With Quote
Old 06-06-2007, 11:04 AM   #2
DCH
Fav Mod: Q-Rack!
Send a message via AIM to DCH
Default Re: Install Guide: ZERO/SPORTS Formula Pushbutton Starter Kit
Damn...and here I thought it was gonna be all complicated! Nifty!
Thanks for the write up!
DCH is offline   Reply With Quote
Old 06-06-2007, 12:11 PM   #3
Is Scared Of Kevin...
are these buttons compatible with 07 sti's because if they are pm me price shipped to 60614
MKTURBO is offline   Reply With Quote
Old 06-06-2007, 03:46 PM   #4
Car: 04 WRB STi
how do the buttons work? is it like the s2000, where i need to put the key in, turn it to on.... clutch and then press the button?
oh yeah! i ordered some rain visors from you guys ,is it too late to add this? lol.. haha i think you guys called to confirm my order yesterday...
jonnyboi is offline   Reply With Quote
Old 06-06-2007, 07:12 PM   #5
same question im wondering....anyways where else can this button be mounted because i have a 07' limited with no empty dins...
MK
Old 06-07-2007, 12:40 PM   #6
Car: 06 WRX protuned stag
Fav Mod: protune
I wan to know this too. Do we need a key?
bzbuzz is offline   Reply With Quote
Old 06-07-2007, 01:08 PM   #7
Trader Rating: (16)
yes we still need a key to start the key for safety purpose like the s2000
Old 06-07-2007, 01:16 PM   #8
Car: '06 CGM/Gold STi
Can this be installed in conjunction with an already existing turbo timer?
ilovecarbs is offline   Reply With Quote
Old 06-07-2007, 01:57 PM   #9
where do i put it if ihave a limited with no empty dins........i want push button start!
MK
Old 06-07-2007, 03:36 PM   #10
Car: 05 Aspen White/Gold
Fav Mod: Öhlins FP
Man that's too easy. I wonder if you can swap that button for say one from the S2000...
alphaSTI is offline   Reply With Quote
Old 06-07-2007, 06:57 PM   #11
i wonder this too because this would solve my no din space issue....just drill a hole on the right side....
Old 06-08-2007, 12:45 AM   #12
here's a link to the product:
http://shop.edoperformance.com/zeros...rx-p-9283.html
illt3ck is offline   Reply With Quote
Old 06-08-2007, 01:30 AM   #13
Car: 05.75 WRX STI
Fav Mod: Protune
Send a message via AIM to stickytires
suscribed
stickytires is offline   Reply With Quote
Old 06-08-2007, 06:53 AM   #14
Nice , simple and easy!!!
Is this kit only for WRX ? What about STI or different car?
auto228 is offline   Reply With Quote
Old 06-08-2007, 07:01 AM   #15
abracious
Fav Mod: Track time
i don't get it. what is the point?
instead on inserting the key and turning it to start you have to insert the key, turn it to on and them press a button on the other side of the steering wheel?
