Old 06-02-2007, 10:49 AM   #1
Default Good pic of 02 sensor
So I'm in the middle of installing my Titek DP. I've the turbo heatshield off and ready to remove the factory DP. I just can't find the 02 sensor wire to remove it. I've checked all the DIY's and there's no reall good picture of where the o2 sensor is. Does anyone have a good picture or some advice? thanks
Edit: my Titek DP is catless and has two bungs. One up near the turbo and one closer to where it meats the mid cat.
Edit#2: 05 OBP STi btw
xtw1ster is offline   Reply With Quote
Old 06-02-2007, 12:02 PM   #2
Car: 04 subaru sti
Fav Mod: 35r turbo kit
Default Re: Good pic of 02 sensor
the o2 sensor is in the middle of the downpipe, you will have to get underneath for that, un plug it then remove the stock pipe then take the o2 sensor off the stock pipe, install in the new downpipe with some anti seize and youre ready to go, btw the plug is right next to your tranny underneath your car
will12345 is offline   Reply With Quote
Old 06-02-2007, 03:21 PM   #3
Thanks for answer, I found it. And she's all done. I can't wait to get tuned!!
