Old 05-29-2007, 08:03 AM   #1
Car: '07 SWP STi
Fav Mod: 30k service
Send a message via AIM to Kickstand
Default APS CAI on '07 STi
Hello all,
A couple of hours ago I began install of my APS 65mm CAI on my '07 STi, and I just wanted to let anybody know that is planning on purchasing that intake, should think twice. It is an awesome looking piece, but the install is a little more involved than you would think. First, the hole in the fenderwill not fit the intake through, therefore I am in the process of dremeling the hole out for the intake to fit. Also you should probably fashion some sort of rubber grommet between the intake and the hole due to the clearance being so tight. I am using a piece of sliced vacuum line. Yeah and you may need some red touch up paint if you are picky to touch up all the scratches you put on it wiggling it into the hole. Just my 2 cents. I just hope the filter fits in there.
Kickstand is offline   Reply With Quote
Old 05-29-2007, 09:09 AM   #2
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
Default Re: APS CAI on '07 STi
you wont see the scractches once its put it there . there is no need to cut anything.. i put mine in an 06 sti and it fit fine just took a while.. filter will fit fine
Old 05-29-2007, 09:49 AM   #3
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
Did you take off your wheel and the plastic wheel well lining?
You'll need to do that in order to get the filter on there. The biggest pain in the a$$ is getting the intake itself into the fender. Like Ikon said, you wont see any of those scratches when its all the way in the fender.
You'll have a different opinion about the intake when the install is all over and you take it for a test drive.
SoaReS is offline   Reply With Quote
Old 05-30-2007, 05:50 AM   #4
Car: '07 SWP STi
I got the littlebugger in there, however, in order to get it to bolt up I had to trim out the hole some. With my mad dremel skills you can't even tell. HAHA. Actually even after I upsized the hole, there was very little clearance. Its in now, and it looks and sounds good I just hope with my tune in two weeks its will help some. I did this and a big TMIC and I wrapped my turboand downpipe yesterdat also, and today is the fuel pump.
Old 05-30-2007, 08:53 AM   #5
Fav Mod: DOM3 Paperweight
Just jam her in.....
Old 05-31-2007, 05:07 AM   #6
Car: '07 SWP STi
Hehe im not a jammer, i like to finesse it. I also like to cut stuff. It fits nicely now though. And a short review, i thought it would make the car jerky etc, but it didn't car is running really smooth
Old 06-01-2007, 10:07 AM   #7
Car: 04 Subaru WRX STI
Send a message via AIM to 1STI2NV
can someone post pics
1STI2NV is offline   Reply With Quote
Old 06-01-2007, 10:48 AM   #8
Car: '07 SWP STi
What do you want a pic of...
Old 06-01-2007, 10:58 AM   #9
of the intake
how it sits and everything
Old 06-01-2007, 03:33 PM   #10
Car: 05 WRX STi CGM
Fav Mod: Element GT52
Send a message via AIM to Ray_Sti Send a message via MSN to Ray_Sti Send a message via Yahoo to Ray_Sti
Ray_Sti is offline   Reply With Quote
Old 06-01-2007, 07:51 PM   #11
Car: 05|WRB|STi
^^ Ray_Sti, i hope your car is tuned for that 70mm
Old 06-02-2007, 07:38 AM   #12
does it come with everything right up to the turbo or no?
Old 06-03-2007, 07:38 PM   #13
Car: 05 WRX STi CGM
yup.. tuned with 70mm n GT52 :-)
Old 06-06-2007, 06:23 AM   #14
Car: UGM 07 STI Limited
Just installed my 65mm last night. What a pain in the A$$. The hardest part was getting the filter element on the pipe once in the fender. Actually I am concerned about mine becuase there is a metal braket on the fender that prevents the filter going over the lip of the APS pipe. I was able to tighten the clamp and there are no gaps, but I really want to get it over that lip.
BTW- I definitly notice much better response and quicker spool of the turbo. Butt dyno can not tell a deifference though. Also the sound is awesome. I am going to get bad gas mileage for the next few weeks.
chrisgman1226 is offline   Reply With Quote
Old 06-20-2008, 10:37 AM   #15
Car: Turd brown 07 STI
Fav Mod: 170mph!
I have a spt short ram on my 07 rite now...i will be installing the 65mm...do i need to buy anything extra or will it bolt rite up afta i take off my spt intake? a;so any tips would be great... I DO NOT WANT TO CUT ANYTHING!
Grey Ghost is offline   Reply With Quote
