Old 10-01-2007, 12:19 AM   #16
Car: 2006 STI
Default Re: Intercooler
Originally Posted by fullerton View Post
the spray does NOT add power. it PREVENTS the loss of power. s
Bosanac_06 is offline   Reply With Quote
Old 10-01-2007, 12:37 AM   #17
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
My spray nozzle has actually been completely clogged before. I cant tell you if it's from tap water or not, but that's what I was using.
Old 10-05-2007, 07:35 PM   #18
Fav Mod: I like it all!
Oh no not this thread again!! WASHER FLUID is safest. It's designed for use in plastic tanks with that pump (same as washer fluid pump), has the proper additives to not clog nozzles (like on your windshield) or create deposits, won't freeze and will not harm the aluminum or paint. No it won't turn your engine compartment or intercooler blue and yes it has the same cooling/evaporative properties as plain old water.
sti_rules is offline   Reply With Quote
Old 10-08-2007, 12:10 PM   #19
Car: 05hmmm White....is i
Send a message via AIM to 105sti
distilled water is preferred since the tap water has calcium and other deposits that will build up in the lines that eventually will clog.
105sti is offline   Reply With Quote
