Old 05-24-2007, 02:35 PM   #1
Car: '07 Sti Limited
Fav Mod: oem short shifter
Default How to remove plastic screws on undertray?
I use to change the oil on my integra all the time. Now with the sti theres a plastic undertray in the way. I tried to take out the bolts, but i broke one so i just gave up and left the tray on and did it as is.. turned out pretty messy. So its time to change the oil again and I want to do it right this time.
Sorry for the noob question, but how do you take out the self taping or plastic bolts (whatever they're called)??? thanks!
SubieGsR is offline   Reply With Quote
Old 05-24-2007, 03:31 PM   #2
Village Idiot
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
Default Re: How to remove plastic screws on undertray?
If you take a flat head screwdriver you will see how there is a lip towards the edge of the plastic clip. Pop it loose and the center of the clip should come out leaving the out ring. Pull it out about 1/4" then pop the ring that was left behind down. The whole thing should then slide out and you will be able to see just how these work. It might take some wiggling but it will come loose.
Old 05-24-2007, 05:05 PM   #3
alright thanks! I'll give that a try.
Old 05-24-2007, 06:54 PM   #4
Titanium Member
Fav Mod: Bill
First time I tried pliers and ended up with a blood blister. Then I pried at it with a screw driver and BAM it popped right out.
Old 05-24-2007, 07:48 PM   #5
Car: WRB 06 WRX STI
Fav Mod: Protune
I hate that under tray... it takes longer to R & I it that it does to change the oil... I know, boo hoo
SonicBoom is offline   Reply With Quote
Old 05-24-2007, 07:53 PM   #6
Muller Chevrolet
Fav Mod: a new 08 STi
never seen people not be able to get clips out...wow LOL.
i take all four of them out first, then drop the bolts.
Old 05-24-2007, 09:18 PM   #7
glad i'm not the only one.
Old 05-24-2007, 09:21 PM   #8
Send a message via AIM to straightouttajersey
easiest way to do it for sure...
straightouttajersey is offline   Reply With Quote
Old 05-25-2007, 01:35 AM   #9
i'll give that way a try tomorrow, thanks guys!
Old 05-25-2007, 01:49 AM   #10
Car: 05.75 WRX STI
Fav Mod: Protune
Send a message via AIM to stickytires
just cut a hole to where the oil filter is. lol
stickytires is offline   Reply With Quote
Old 05-25-2007, 02:11 AM   #11
Car: Da Name sez it all
Fav Mod: Squeeky brakes -.-"
I broke a few of the plastic screws cuz they were so damn stubborn sometimes... but a flat head came to save the day
SubaSTi04 is offline   Reply With Quote
Old 05-25-2007, 02:16 AM   #12
you might want to have your oil changed at the dealership if you can't handle the plastic pop-rivets.
illt3ck is offline   Reply With Quote
Old 05-25-2007, 06:40 AM   #13
The clips trap dirt granules which cause them to be hard to remove. I tap on them a few times to dislodge the dirt. Then pop them out with a flat blade screwdriver, then remove the 10mm bolts. Works pretty well.
DB
Old 05-25-2007, 06:49 AM   #14
Fav Mod: FYI, I'm a dude
the key to these plastic screw is to not pull the center clip all the way down. if you do, you'll just open up the prongs again. if the whole thing doesn't come out easily, push the center clip back up a bit and pull from the ring again. it should take little effort to remove them.
Old 05-25-2007, 09:12 AM   #15
Car: 04 subaru sti
Fav Mod: 35r turbo kit
go buy yourself a 30 degree or 80 degree snap on plastic push pin puller, its worth its weight in gold! haha, but really, one of the best tools ive ever bought and i use it everyday, makes pulling out any push pin a breeze
will12345 is offline   Reply With Quote
