Old 05-21-2007, 06:55 AM   #1
Fav Mod: Protune
Default vortex generator installation
alright here it is
http://cgi.ebay.com/ebaymotors/SUBAR...16954856QQrdZ1
the paint is an exact match my 2004 black STI.
is there a 'proper' way to install this, since the last one i put on flew off after about a month of it being on, and i put LOADS of super heavy duty double sided tape.
If you look closely, the little 'teeth' on the ends of the vortex generator (VG) should i cut them off? if anyone has got one on, or helped put one on, do u remember if those were on?
any help would be appreciated...
cheers,
Alex
kungura is offline   Reply With Quote
Old 05-21-2007, 08:16 AM   #2
Default Re: vortex generator installation
On the listing, it reads the color as "metallic black pearl." Our 04 Stis came with JAVA BLACK Pearl. Hope it was a typo on his part!
volkl23 is offline   Reply With Quote
Old 05-21-2007, 09:05 AM   #3
Car: 2005 STI
Fav Mod: Methanol
Clean very well all surfaces, use quality doublesided tape, and heat up both surfaces before apply, and hold till it cools. Mine has been on for maybe 3 months now and seems okay.
xrocket21 is offline   Reply With Quote
Old 05-21-2007, 12:20 PM   #4
Fav Mod: Protune
I just got it, the color name doesn't really matter, it is however an exact match as java black... :-)
i'll clean all surfaces, and get the scotch super heavy duty double sided tape (meant for outdoors) and put a bunch of it on.
It also came with some silicone glue this time, should i put that on the car side of the double sided tape, or the vortex side? or both???
cheers!
alex
Old 05-21-2007, 12:31 PM   #5
All day everyday
Fav Mod: Debt
Trader Rating: (14)
Send a message via AIM to DjChieNa
i wouldn't recommend using silicone glue on there as it will hurt your paint and maybe rip your paint off if you decide to remove it. Just use a real heavy duty double sided adhesive and prep both the roof and and generator by wiping it with alcohol for better adhesion contact. Heat both parts with a blow dryer before sticking together, and then install it and hold it in place for a bit.
DjChieNa is offline   Reply With Quote
Old 05-21-2007, 07:00 PM   #6
Fav Mod: Protune
alright, so i've primed it and put the double sided tape with this special plastic adhesive to put in between (it's the kind that has 2 tubes and u have to mix it - i tried it on a small piece to see if it sticky, and once put in between, you can not split the two pieces!!)
tomorrow i'm going to install it on the car and hold it in place for a bit, and fingers crossed, it'll stay on!!
thanks for some good tips guys!
Old 05-21-2007, 08:26 PM   #7
Car: 01 JDM STI
Fav Mod: JDM cupholders
I still don't understand why you're sticking two pieces of double sided tape together, thats not what It's designed for. If there are issues with it contacting your roof in certain areas buy a thicker grade of tape and use it in those areas.
escos is offline   Reply With Quote
Old 05-22-2007, 01:17 PM   #8
Fav Mod: Protune
Well if you can find me a 7-9mm double sided tape that is super heavy duty, water proof, not spongy/foam, and can withstand 130mph winds and lift, then let me know, but i'm telling you, it just won't work with one layer.
When/if you get one it might make more sense.
Old 06-28-2007, 01:36 PM   #9
Car: 06 Subaru WRX STi
Fav Mod: HKS SSQ BOV
Send a message via AIM to SENSEIMACK Send a message via MSN to SENSEIMACK
I thought about the vGen.. even thou i like it the way it looks on the evo, its one of the few things i like about the evo. I thought it would be a disgrace to take that from the Evo and put it on my car... Out of pride i decided not to do it, but as people say on this forum... Its your car...
SENSEIMACK is offline   Reply With Quote
