Old 05-20-2007, 03:17 PM   #1
Car: '06 WRX blue
Fav Mod: Cobb Shortshifter + bushings
Default rear strut tower bar
anyone have experience installing this in an '06 WRX? just from a quick look the front strut tower bar looks quite straight forward to install, but I can't see where the rear one might go. It looks like there is no access to the top of the rear strut towers.
on the same lines: anyone with opinions on whats the best way to go, front, rear, or both? even stock I get understeer on hard cornering. I was looking at the Cobb tuning site, and they only offer the rear bar, not the front. just wondering if there's a good reason for this...
TIA!
soundemon is offline   Reply With Quote
Old 05-20-2007, 06:27 PM   #2
Car: 06 STI
Default Re: rear strut tower bar
To install the rear you have to pull the rear seat back & the top of the struts are at the upper corners near the corresponding pillar. The front is basically for show & no real advantage to put one on based on the strut mount locations on the body (basically no flex here stock). The rear will improve structural stiffness some. As far as oversteer you're out of luck, the strut bars will have no effect on that. Look at swaybars & endlinks fr & rr and you'll see a night & day difference in handling. It'll still push when cornering hard though untill you learn to use your right foot to help steer. I personally went Cobb Stage 1 on the suspension Swaybars fr & rr, upgraded the end-links & rear strut bar (you'll love it). Best bang for the buck next to Stage 2. Do a search & you'll find an install here, I don't have the link, but you should pull it w/a search.
highwayman is offline   Reply With Quote
Old 06-02-2007, 08:05 AM   #3
Why the JDM STI all come with the front upper tower bar and Mitsu EVO come with stock one also?? They all make that for show only ???
auto228 is offline   Reply With Quote
Old 06-02-2007, 04:34 PM   #4
DCH
Fav Mod: Q-Rack!
Send a message via AIM to DCH
GarageSpec.com has a picture of their BeatRush Rear Strut Bar that'll give you an idea as to how it's installed.
That Beatrush bar looks hella beefy!
DCH is offline   Reply With Quote
Old 06-03-2007, 10:52 AM   #5
Car: 06 STI
Maybe do a search on front strut bar and you too would find out a front strut bar doesn't benefit our cars. The placement & angle of the strut towers are not a weak point for flex on our cars. I never stated for every car. Anyways thx for the info, SA. Why would I tell him to waste money on a front strut bar when he can spend that towards a real benefit like sway bars & endlinks.
Old 06-03-2007, 01:47 PM   #6
wdb
dances with roads
Yes do swaybars before a front strut tower bar, unless you're one of the many afflicted with the dreaded windshield creaking/cracking issue. Then get a front strut tower bar ASAP, any one will do.
Old 08-08-2007, 10:11 AM   #7
Car: 1998 Impreza GF8
Send a message via MSN to RFFG
Bump*
I need to do my rear strut brace...
Does anyone know if there's a write up on this?
RFFG is offline   Reply With Quote
Old 08-08-2007, 10:34 AM   #8
Car: 06 OBP
Fav Mod: Catless....and smoke
the rear seat comes out real easy, the two bolts near the floor take off the bottom half, and there are bolts on the inside near the seat belts and then the top comes off, the seats weigh about 3 lbs total max.. real simple, hope that helps
Old 08-08-2007, 12:55 PM   #9
STI PILOT
Fav Mod: MY GARAGE PERIOD
wife did her own took her all of 30 minutes from start to finish. pretty simple
Novtec1 is offline   Reply With Quote
Old 08-09-2007, 12:00 PM   #10
I'm doing it Saturday, I'll snap some pics
Old 08-10-2007, 07:42 AM   #11
Car: 04
Default Re: rear strut tower bar-
try this:
http://www.oakos.com/wrx/installs/RSTB/index.htm
2dino is offline   Reply With Quote
Old 11-29-2007, 01:32 PM   #12
Car: 05 WRX STI OBP
Fav Mod: learning how to heel toe
yes this is true this isnt a weak point for the sti but i always thought that the point of strut bars are to join th top of the shocks to make a square and make a stiffer car when turning so it doesnt flex
Old 11-29-2007, 01:38 PM   #13
Muller Chevrolet
Fav Mod: fp green
you're right but with our cars, the strut placement is right by the firewall which aids in the stiffness of them.
Old 12-01-2007, 07:10 AM   #14
Car: 07 Subaru WRX STi
Thumbs up Re: rear strut tower bar
I just did my front strut tower bar, and it did make a diffrence!!! You can tell right away!!! Gotta try it before you knock it!!!! i did a tein bar (100. on ebay)
chitownsti07 is offline   Reply With Quote
Old 12-01-2007, 08:41 PM   #15
Car: 05 WRX STI OBP
same here i did my first on my sti and what a diff. i was a pain to put in because the ac lines but worth it
