Old 08-08-2007, 03:10 PM   #31
Titanium Member
Fav Mod: Modified Stock Heat Shield
Default Re: Recommendations for a good hydraulic jack?
Well...it works great so far. I really needed something to take to autox that would be light, slide under the lowered front quite easily, and cheap. This meets those criteria.
Old 08-08-2007, 03:33 PM   #32
Car: 06 STI
Check out this low profile omega jack.
http://www.tooltopia.com/index.asp?P...D&ProdID=11737
http://www.shinnfuamerica.com/(S(pqy...on.aspx?ID=763
I can't vouch for the overall quality or durability of this product because I've only used it a few times and it's the first omega product that I've used. So far so good. My car is at stock ride height and has a ravspec lip (v limited replica). This jack clears the lip (barely) and reaches all the way to the crossmember! (You will probably still need to use blocks for a lowered car). It also allows you fully pump the jack handle when lifting the car. I can't imagine that there are many floor jacks out there that have a lower profile than this.
I used to use a crappy small $20 floor jack from checker. It fit under the car, but I only had room to pump the jack lever about 1-2 inches per pump (basically a lot of work and time involved just to jack up the front of the car).
I was shocked to see the price when I searched the link for you guys. I paid $179 shipped from tooltopia for this about a year ago.
Deuce Cam is offline   Reply With Quote
