Old 05-30-2007, 12:54 PM   #16
Car: Black 07 WRX STi
Send a message via AIM to chrobis
Default Re: How To: complete idiot's guide to getting your car up on jackstands
I bent the same rail on my Celica fairly easily with just the jack alone... I actually switched to using my crap OEM jack anytime I had to lift up the car, harder to get the car up but it lifts the car really well and I just left it in place as a jack stand (and used another OEM jack if I needed to lift in 2 places).
chrobis is offline   Reply With Quote
Old 05-30-2007, 01:02 PM   #17
Car: 08 STi, SSM
if the pinch weld is bent already, why bother using the OEM jack? That seems pretty dumb to me, especially if it's more difficult to use.
Old 06-11-2007, 07:21 PM   #18
Fav Mod: I can only choose one?
Send a message via AIM to Stargazer
I don't like using the pinch welds, and I don't have an adapter so after watching a tire shop lift my car one day, I put my floor jack in a spot just inward of each pinch weld.
This is a picture of the left front wheel with the floor jack in place:
There's a row of four bolts surrounded by plastic. The 3rd one from the front is raised (which you can see in the picture), and I put the jack on the bolt behind it.
I've used it several times now to swap wheels with no flexing, creaking, or other scary noises . Of course, now that I've posted the picture someone will probably say I've done irreparable damage to my car .
Stargazer is offline   Reply With Quote
Old 06-11-2007, 07:56 PM   #19
Car: '06 STI
Fav Mod: air freshener!!!
OMG! You have ruined your car!!!!!
JK.....
Nice clean undercarriage. Time for an ALK kit!
Old 06-11-2007, 08:46 PM   #20
Car: '05 STi AW on Gold GC05
Fav Mod: AVO500
that seems to work for me. I've been jacking there for yrs, no prob so far. seems strong
Left Coast STi is offline   Reply With Quote
Old 06-11-2007, 10:46 PM   #21
I would never put jacks on those seams.
Here is the proper (and Subaru recommended) way to jack your car:
http://scoobymods.com/forums/showthread.php?t=2673
illt3ck is offline   Reply With Quote
Old 06-11-2007, 11:35 PM   #22
Hmm... I hate having to log in to see pictures . I can't remember the user name I signed on with way back when .
Old 06-12-2007, 02:14 AM   #23
Car: 2007 WRX STi
Fav Mod: Dual OEM subwoofer daisy chain
Yeah, that's pretty dumb. I registered last year...
Gouki is offline   Reply With Quote
Old 06-12-2007, 06:57 AM   #24
Car: 2oo5 cgm STi
I'm sure they work fine, though I have also read that people don't like to place stands on the subframe. But I wouldn't say the jack stand points are "Subaru recommended" - I have never seen anything official from Subaru on that point.
Here are the jack stand pics, re-hosted. The actual jack points used in that thread (front plate and rear diff) have been shown already.
Old 06-12-2007, 11:47 PM   #25
you have to register to post here ...
Old 06-12-2007, 11:48 PM   #26
The pinch welds as jack points are only to be used by the oem jack that's in the back of the car in case of emergency as it has a slot designed to support the car at that point. You WILL crush those pinch welds by using a standard jack and supporting the weight of the vehicle on jack stands.
Old 06-13-2007, 12:14 AM   #27
Car: 07 STi
Fav Mod: upgrade from my WRX muhaha
finally, great thread btw.
Originally Posted by austinpike
I hate the idea of using a chunk of wood - wood splits. I have also heard of using slotted hockey pucks for the same thing. I would really like to see a (metal) product that adapts from the stand to the seam, sort of a sleeve that caps the stand and has a slotted fitting like the OEM jack.
my friend has the same jack as the one in the OP. i just took some cardboard, bent it into a square so that it had like 3-4 layers, taped it up, and put it in between the jack and my rear diff...i think it worked great as a cushion to protect the diff...
STI_818 is offline   Reply With Quote
Old 06-13-2007, 12:41 AM   #28
http://www.ionthruster.com/sti/sprin...tandsfront.jpg
Thanks for that! It looks like almost the exact same spot that I'm using so I feel better .
Old 08-17-2007, 11:37 AM   #29
Car: 06 CGM STi
Fav Mod: brake dust generators
Send a message via AIM to osbjmg
Thanks for the crystal clear picture. That's where I would like to put the jack stands. I think this looks like the most solid spot anyone has come up with yet.
When you put your jack there, where do you place the stands? I think it would be easier to jack up on the crossmember / rear diff. and put the stands where you have your jack.
I was wondering if that was subframe or just some plastic - it's covered in plastic I guess to help with corrosion but I didn't know what was under it.
osbjmg is offline   Reply With Quote
Old 08-17-2007, 12:05 PM   #30
Fav Mod: Rustoleum Flat Black
The plastic you mention is just some aero-dynamic bling. There is steel under there. You can easily pop this plastic off and investigate to give your self a mental picture of what it covers. Thats what I did. The body jack points are a necessary evil on a lowered car. I would much prefer to be able to reach the spot shwon in that perfect picture.
*Nice jack BTW
grambo is offline   Reply With Quote
