Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 03-15-2008, 01:54 PM   #51
Car: Insane 06 Evo MR
Fav Mod: myself
IWSTI Addict since: Feb 2007
Default Re: How To: complete idiot's guide to getting your car up on jackstands
I just put an STi up on those little slits by the sideskirt, thinking "hey my Evo uses this for a jack stand point why not" and as soon as I lowered the car down onto the stand, the whole thing just bent. I have no idea why that would happen, or why so many of you say its a good place to put stands. Is there something totally odd with the car I was with or what, because thats not safe.
M3Jedi77 is offline   Reply With Quote
Old 03-15-2008, 04:21 PM   #52
Feedback Score: 2 reviews
Car: UGM 08 STi
IWSTI Addict since: Mar 2008
Originally Posted by stim View Post
As described by Rantar_STi:
To visualize where to place the jack stand look at the first picture of this thread showing the jack stand right under the pinch weld. If that jack was rotated 90 degrees and moved towards the inside of the car (i.e. towards the drive shaft) such that it would be located immediately behind (inboard of) the pinch weld (about 1/8") and immediately below the raised area of the floor panel, that would be the correct place to put the stand (and centered on the raised area of the floor panel).
I agree with this 100%, as well as the originally described jacking points. The floor just inboard of the pinch welds is shaped to accept jack-stands. I am always putting my car on stands to change to track wheels and brakes. I use a soft thin piece of wood in the jack pan.
ding ding ding, we have a winner.
This area is reinfored and the correct place to put stands if you don't want to bend anything. You also can't compare a lift to jack stands. A lift does not bend the pinch welded area because it distributes the weight over a larger area and raises the car evenly. A typical lift arm is 4-6 inches wide in comparison to a 1 inch wide jack stand.
Also forgot to add, the stock jack does not use the location the stands are using in the picture. There is a slit in the stock jack which guides you into the correct area. 100% of the weight is supported behind that seam in the reinforced area. There are two marks on the seam, between them is where you place the stock jack to line up with the support.
omegax is offline   Reply With Quote
Old 03-15-2008, 09:45 PM   #53
AMG
Gunnin' it.
Feedback Score: 4 reviews
Car: '05 STi
My StuffSubaru Parts
IWSTI Addict since: Sep 2006
Send a message via AIM to AMG
can we get a pic of this?
and bump for m3jedi77's question...
If the pinch welds are bent to hell, does it really matter? They can still support the car, right? (Sorry, this is just me thinking outloud...)
AMG is offline   Reply With Quote
Old 04-01-2008, 07:39 PM   #54
STI Guru
Feedback Score: 18 reviews
IWSTI Addict since: Aug 2006
Bumping this thead, very important for alot of people.
Old 04-10-2008, 01:14 AM   #55
Car: '04 Sti
IWSTI Addict since: Mar 2007
Bump for:
"What is the best way to jack up the front if I have a huge aftermarket skidplate?"
'04 Black STi is offline   Reply With Quote
Old 04-10-2008, 01:56 AM   #56
Car: 05 STi CGM
Fav Mod: JDM Foglights
IWSTI Addict since: Oct 2005
Nice write up. Regarding the picture showing the jack on the rear diff:
I would recommend sliding the jack further under the car so that the saddle isn't under the rear cover- so its footprint is only on the case of rear diff. Not that I've ever seen it be a problem, but if the cover wasn't flush at the bottom you could stress the cover bolts & cover. Not required but good practice to avoid ANY issues, I guess.
SCOOBYTRAP is offline   Reply With Quote
Old 04-10-2008, 08:25 AM   #57
Feedback Score: 1 reviews
Car: STI
IWSTI Addict since: Jan 2008
Bump for pic request. Can someone take a picture of this?
Bloo is offline   Reply With Quote
Old 04-10-2008, 11:07 AM   #58
The Stig
Fav Mod: 'STi' Licence Plate! w00t w00t
IWSTI Addict since: Feb 2008
Originally Posted by mxpop View Post
That's what I do and I still have all 9 fingers to show for it......
HAHAHAHA
Old 04-13-2008, 09:46 AM   #59
Bump again!
chanders is offline   Reply With Quote
Old 05-03-2008, 10:43 AM   #60
Car: '08 WRB STi
Default Help - '08 STi jack / stand points
With all the plastic under there, can we actually see where the best points are? I'm serious newbie at this
Smiley is offline   Reply With Quote
Privacy Policy
