Old 05-09-2007, 08:53 AM   #1
Default How to install Koni inserts
I have searched but can not find the answer.
Please help
luckie8 is offline   Reply With Quote
Old 05-09-2007, 10:08 AM   #2
Car: 06' STi, de-pinked
Fav Mod: RCE Tarmac II, +27 Enkei RPo1
Default Re: How to install Koni inserts
I was always under the impression that you can't use Konis with STi struts. The Koni is just to wide to fit. On 04' STi, you can use a WRX struts with Koni insert, but other than that, I think we're SOL.
sucks because Koni still makes the BEST insert for daily drivers.
hypa is offline   Reply With Quote
Old 04-28-2008, 05:17 AM   #3
Fav Mod: Driving School / Trunk swap (no attention ftw)
^^ just for future reference: THIS IS INCORRECT
for 2005+ STi's, you can buy housings for the front from Ground Control, and then use Koni inserts in the rear in WRX housings. All rear housings will fit the 2005+ STi's.
This is an excellent, affordable option for those looking to replace struts / go with custom coilovers / etc.
See Stretch's thread in the Suspension section for more info. Just ordered mine from Mark @ Ground Control
Jesse
mgsm666 is offline   Reply With Quote
Old 04-28-2008, 05:17 AM   #4
p.s. there is a great writeup Stickied on NASIOC detailing how to do inserts in wrx housings too.
