View Poll Results: Did you remove the bumper to do this?
yes. 2 18.18%
no. 9 81.82%
Voters: 11. You may not vote on this poll
Old 05-08-2007, 06:59 PM   #1
i eat cones
Fav Mod: catless
Lightbulb How-To & FAQ/Discussion- Perrin Front license plate delete
SOLVED!
without removing your bumper!!!
you need THESE! :
i have an extra set of these plugs if anyone needs. i can ship them to you. i can get more if a few of you need them! let me know
i got these from my work in parts... (GM Dealer)
should be able to find them in other locations, ill check and post any up.
what you need:
*perrin front plate delete (www.perrinperformance.com)
*allen key for the provided screws
*2x plastic push in tabs (above)
and
10 minutes
process:
-take anything out of the front plate screw holes.
-push in the said plastic tabs, they should pop right in with not to heavy of a force
- put the perrin plate up to the area, and use the screws provided. you will need the correct allen key.
*note- it will concave a tiny bit, it is normal because it cannot sit flat.
simple right?
results! awesome look for a decent price!
Szumita is online now   Reply With Quote
Old 05-08-2007, 07:53 PM   #2
Car: 07 SWP STi
Fav Mod: Perrin Exhaust
Default Re: help! perrin front plate delete.. alternate way to install?
doesnt it just use the pre existing holes for the license plate???! is this what you are trying to install?
Dragicon is online now   Reply With Quote
Old 05-09-2007, 04:51 AM   #3
i eat cones
Fav Mod: catless
exactly. but you need the bolt BEHIND the bumber to screw it in...
Old 05-09-2007, 05:42 AM   #4
I got the autospeed version of that and it came with star drive screws that thread into the license plate holes. The screws weren't normal star drive though, there's a small peg in the center of them so they require a matching driver with a hole in the center (i guess to prevent it from getting stolen as easily). I think you could probably find screws that'd work for you at home depot though. Or you could go to autozone and just get regular license plate screws and that should work too.
KrazyKarl is offline   Reply With Quote
Old 05-09-2007, 05:44 AM   #5
abracious
Fav Mod: Track time
just make sure they are stianless, you don't want them rusting come winter.
Old 05-09-2007, 05:49 AM   #6
Fav Mod: alcantara...everything!
I dunno, auto grade double sided tape (red) ?
Old 05-09-2007, 06:38 AM   #7
i eat cones
Fav Mod: catless
hmm yeah. i thought of tape, but i donno how well it would hold. i guess auto grade would, so yeah. im gonna go to home depot after school and look for some screws that will be bigger and fit. ill keep this updated... maybee anchor screws...?
Old 05-09-2007, 06:46 AM   #8
Car: '06 Aspen White STI
Fav Mod: RCE Tarmac 2
Some 3M heavy duty double sided tape will be more than enough to hold it into place. Most hardware stores sells them.
Drag-On is offline   Reply With Quote
Old 05-09-2007, 06:49 AM   #9
i eat cones
Fav Mod: catless
ill have to grab some of this if i cant find any screws.
Old 05-09-2007, 06:56 AM   #10
Fav Mod: HKS CARBON TI
id say just look for some screws that arent too ugly and that will fit nicely into the hole
Old 05-09-2007, 09:08 AM   #11
Muller Chevrolet
Fav Mod: fp green
just use normal license plate screws that will fit through the holes.
a bolt and nut would be stupid.
Old 05-09-2007, 09:15 AM   #12
Car: 06 STI...FP Green
I have the same one and I don't have to take my bumper off, my hand fits behind the bumper fine... what is blocking you from putting your hand behind the plate?
Chris is offline   Reply With Quote
Old 05-09-2007, 10:19 AM   #13
i eat cones
Fav Mod: catless
theres some kind of styrofoam there. or something.
Old 05-09-2007, 11:40 AM   #14
Wierd. Mine must have been removed when they did the FMIC (bought the car used)
Old 05-09-2007, 01:44 PM   #15
i eat cones
Fav Mod: catless
that explains it.
but anyways... another size screw DOES NOT work. the hole in the plate delete is the same size, or smaller than the stock holes in the car. so it dosent thread in...
sigh.
