Old 05-22-2007, 09:10 AM   #46
Car: 08 STi, SSM
Default Re: DEFI BF install -Step by step with pics
You can't just call it 1/8 thread and expect it to be the same. The 1/8 thread used on Subarus is 1/8-28 BSPT which is slightly different than the 1/8-27 NPT thread commonly used with USDM gauges. OP is calling the Defi sensor 1/8 PT which is slightly misleading, IIRC it is 1/8-28 BSPT so it matches up fine with the stock oil galley threaded plug. You can use a 1/8-27 NPT sender, just wrap it up a couple of turns with teflon tape and you should be fine, there are plenty of people that are running this way. Personally, I don't do things like that, but I have access to pretty much any machinery I need to change the threads or make my own plugs.
Old 05-22-2007, 02:03 PM   #47
Oh wow, I didn't know that. I apologize for my noobness. I am still a bit confused, you're saying that I can use the either sensor, to get oil temp but I might have to wrap with teflon tape to help it fit right?
sdkim7 is offline   Reply With Quote
Old 05-22-2007, 03:02 PM   #48
Car: 08 STi, SSM
Teflon tape is good insurance with any of these tapered thread fittings. The only time I don't use Teflon tape is when I'm using Swagelok type fittings or fittings where the nuts have potential to split. I'm not specifically saying you can use either sensor, I'm saying you will have one sensor or the other supplied by the gauge manufacturer. While you can thread the NPT into the subaru part, BSPT and NPT are not the same threads. At some point you will be making your own threads in the plug, which isn't ideal in my opinion. I don't wish to add metal to my oil if I can help it. You can also buy BSPT to NPT conversions, there were several threads on nasioc about them a while back, I don't know if that info has migrated to this site.
Old 05-23-2007, 04:21 AM   #49
Car: 05 STi - Black
Fav Mod: No Lien
Just to aleviate confusion:
The Subaru plug is BSPT (otherwise known as PT)
The DEFI Oil Pressure sensor is BSPT (PT)
The METRIC (celcius) DEFI Oil Temperature sensor is BSPT (PT)
The IMPERIAL (farhenhiet) DEFI Oil Temperature sensor is NPT
The Oil pressure sensor comes with BSPT to NPT adaptor, so that you can install your pressure sensor into an NPT hole, commonly found on oil filter sandwich adapters.
DEFI recommends in the instructions that you use teflon tape, regardless of whether your inter-mixing PT and NPT threads.
Old 05-23-2007, 07:18 AM   #50
This is where I'm having the issue...the oil filter adapters don't fit the 06 WRX...found that out the hard way . So I'm trying to find an alerternate way of installing the sensor which is 1/8 NPT to get a reading for oil temp. I've been searching around for an adapter that goes from the 1/8 NPT to BSPT but the problem there is the temp prob doesn't actually make it all the way down cause the adapter is in the way so I'm affraid I won't get a good reading...
Old 05-23-2007, 01:35 PM   #51
Car: 05 STi - Black
Fav Mod: No Lien
Remember that the oil system is pressurized in those gallery areas. Your temperature sensor doesn't necessarily have to be protruting into any oil flow per se to get a reading (as you would with say, EGT). With pressures upwards of 100psi, the oil will push itself up into that adapter and the probe will take a reading with no ill effects.
Old 05-24-2007, 04:26 PM   #52
Car: 05 STi - Black
Fav Mod: No Lien
Bump for the final stage
Old 05-27-2007, 08:00 PM   #53
Car: 05 Subaru WRX STi
Fav Mod: Short Shifter
Send a message via AIM to zell_06 Send a message via Yahoo to zell_06
Default Re: DEFI BF install -Step by step with pics - 24 May - INSTALL COMPLETE
Good luck with the install everyone.
zell_06 is offline   Reply With Quote
Old 05-28-2007, 01:08 AM   #54
Car: 06 STI
Fav Mod: Your MOM!!
damn. glad its done, superb write up, thanks
Old 06-01-2007, 08:36 PM   #55
Car: 06 Yamaha R6 Raven
Fav Mod: NO car payments!!
Send a message via AIM to STIfreak7
In the middle of my install now, finishing it up tomorrow (hopefully) Where can I get a NPT to BSPT adapter for the Imperial oil temp gauge, didnt know I would need one, but glad to find out ahead of time.
STIfreak7 is offline   Reply With Quote
Old 06-02-2007, 04:47 AM   #56
Car: 05 STi - Black
Fav Mod: No Lien
Try www.egauges.com
Few other places you could try:
- Home Depot
- Any autoparts store
Old 06-02-2007, 09:24 PM   #57
Car: 08 STi, SSM
you missed this thread?
What is needed for 1/8 NPT OP Sender in Galley plug install?
Old 06-21-2007, 10:36 AM   #58
Car: 07 STI
Fav Mod: Cosworth block
Nice write up, I started my install last night going by your write up.
Thanks for taking the time to do a how to on this.
Bill
HDMLNIUM is offline   Reply With Quote
Old 07-20-2007, 05:39 PM   #59
Nice tutorial, it's much appreciated
skibbz is offline   Reply With Quote
Old 07-22-2007, 08:41 PM   #60
Car: 2007 WRX STi
Fav Mod: Dual OEM subwoofer daisy chain
Great write up. I just bought a set of STI GEnome gauges on ebay, can't wait to install. I also have the accesory STI red intercooler hose to put on too.
Gouki is online now   Reply With Quote
