Old 05-02-2007, 10:54 AM   #1
Car: OBP 05 STi
Fav Mod: 07 STi Head Unit Swap
Send a message via AIM to xtw1ster
Default SPT Intake ECU reprogram
So I installed my SPT Intake without a hitch. I did remove the + connection to the battery as instructed. It runs like a champ. I did notice yesterday when I was refueling. There's a warning sticker by the gas cap that says not to continue fueling once it stops. A practice I have done since I got the car. I noticed that after I got in my car that the Fuel needle didn't peg out "Full" like it normally did. Anyone seen or heard of this? thanks
xtw1ster is offline   Reply With Quote
Old 05-02-2007, 11:04 AM   #2
Fav Mod: Me.....
Default Re: SPT Intake ECU reprogram
reset the ecu again or try topping it off....I wouldnt worry about it if it was me. Heck my gas gauge hasnt worked for 3 months now. :/
Old 05-02-2007, 11:05 AM   #3
I'm Jim Halpert
Fav Mod: Ricer Flyby
u mean top off? ive done it a few times but its only dangerous cuz it can spill out onto you. ive never heard of it not pegging out at full before
Old 05-02-2007, 04:46 PM   #4
Car: 06 sti wr blue pearl
if you keep filling the tank the fuel will come up the filler neck and go down the tube for the charcoal cannister for the evap. emissions system, if something fails this may not get covered by warrante because you were warned by the sticker
badassbusa is offline   Reply With Quote
Old 05-02-2007, 05:50 PM   #5
Car: 07 STi Ltd. #575
Fav Mod: SPT Power Pack
Depending on where the needle was before the fuel fill-up will result in a slower moving needle on first start after the fill-up. When I fill from half or greater the needle sometimes takes a while to move, but when I'm lower than half, it goes right up.
Subby tech told me that it's one of the Subby/Impreza quirks.
Lator
BOILator is offline   Reply With Quote
Old 05-02-2007, 06:25 PM   #6
Car: 2005 WRB STI
Fav Mod: radar detector...
Send a message via Yahoo to nolag04
same here...
nolag04 is offline   Reply With Quote
Old 05-02-2007, 06:28 PM   #7
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
When you fill up, do not Fill it up as fast as it can, put the little thing in the middle so it flows at a medium rate. The foam in the gas tank causes it to think that it is full, even though it isnt. If you fill up slower then it wont foam as much and your needle will go to Full.
Old 05-02-2007, 10:17 PM   #8
Car: OBP 05 STi
Thanks for all the answers. I'll re-fill tomorrow and see how it goes. Now i just gotta figure out how to set my Apex Turbo Timer to auto sense A/F mixture. Thanks again everyone.
Old 05-07-2007, 09:12 AM   #9
Car: OBP 05 STi
It worked out just fine. I filled up only holding the handle 1/2 way. Good Advice
