Old 04-29-2007, 07:01 PM   #1
Car: 06 WRX STI
Fav Mod: Front license plate delete
Default The best way to take out 06'+ fog light covers
I know this seems stupid but I don't want to scratch my paint. How do you remove the 06'+ factory fog light covers?
crand002 is offline   Reply With Quote
Old 04-29-2007, 07:26 PM   #2
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
Default Re: The best way to take out 06'+ fog light covers
I just removed my bumper on my 07 like two weeks ago and if you did that you would have good access to the back of it I would assume to remove it instead of trying to do it from the front side. Not that it is hard but i posted a thread in here about removing the 07 bumper so you can see where all the clips are at.
CenCali07STI is offline   Reply With Quote
Old 04-29-2007, 07:28 PM   #3
HowTo Contributor
Car: 06 STi
Fav Mod: LED Windshield Washer Nozzles
If you dropped the undertray, you can probably reach them from behind and push them out.
rube23 is offline   Reply With Quote
Old 04-29-2007, 07:33 PM   #4
Car: 2007 OBP Subaru Impr
Fav Mod: Gearing in 07' STi FTW!!!
Send a message via AIM to sti002
take a really thin flat head screw driver. lay a piece of electrical tape over the tip of it so its flat and then insert it in the little slit on the front of the cover at the bottom middle. While inserted lift up and pull towards you and it should pop right out
sti002 is offline   Reply With Quote
Old 04-29-2007, 07:35 PM   #5
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
sounds good.
Old 04-29-2007, 07:56 PM   #6
Fav Mod: I can only choose one?
Send a message via AIM to Stargazer
You can see the spot where you need to put the screwdriver here:
Stargazer is offline   Reply With Quote
Old 04-29-2007, 08:20 PM   #7
Car: 06 WRX STI
Perfect, I will try the screwdriver way first. Thanks everyone!
Old 04-29-2007, 08:30 PM   #8
Car: 89 GT-R32
Fav Mod: no brake fade
Send a message via AIM to BrewPubeaver Send a message via MSN to BrewPubeaver Send a message via Yahoo to BrewPubeaver
i can do mine with just my hand....
BrewPubeaver is offline   Reply With Quote
Old 05-07-2007, 08:48 PM   #9
Car: 06 SGM STI
Now thats talent...
sauuce is offline   Reply With Quote
Old 05-08-2007, 04:13 AM   #10
Car: 06 BLACK STI!!!
Fav Mod: Annual Bonus!!
Send a message via AIM to all4bspinnin
same here, if you put your hand under the car, you can reach in between the undertray and the bumper and push them out from the backside...
all4bspinnin is offline   Reply With Quote
