Old 04-30-2007, 04:07 PM   #16
Car: 2006 Subie STi
Fav Mod: Turbo-back exhaust
Send a message via AIM to FastieMagee06
Default Re: diffuser dosent fit after hks hipower
well, If you dont want to cut it jsut mount everything losely ans see if it will fit. Then just tighten down everything. Cutiing it is way easier though. Its more simple than it looks.
FastieMagee06 is offline   Reply With Quote
Old 04-30-2007, 05:44 PM   #17
Car: 07' STi - Stg 2 1/2
Fav Mod: Too many to choose from
Send a message via AIM to xxINKxx
dremel FTW..mine fits awsome
xxINKxx is offline   Reply With Quote
Old 05-21-2007, 09:21 PM   #18
Car: '07 Sti Limited
Fav Mod: oem short shifter
Sorry for bringing this thread back, but..
this is probably a dumb question, do you take the diffuser out first and cut it? Or can you cut it with it still attached to the car? Anyway to do this without a dremel?
SubieGsR is offline   Reply With Quote
Old 05-21-2007, 09:29 PM   #19
Fav Mod: HKS CARBON TI
i dont think it matters whether you take it off or not but itd probably be easier to do with it off the car. If you dont have a dremel, you can just use any old saw to cut it off. It wont be pretty but it'll work
Old 05-23-2007, 01:55 AM   #20
will do! Thanks!
Old 07-05-2007, 02:40 PM   #21
Car: 2007 Limited STI
Fav Mod: widebody
hahah this is an old thread, i have a carbon ti now, but i finally got off my ass today and proceeded to cut the diffuser. took me like 45mins cause i had to use a hand saw and i cut it like 5 times but it looks pretty good. ill put a picture up tonight
Josh[ua] is offline   Reply With Quote
Old 07-05-2007, 02:51 PM   #22
Car: 2006 Subaru WRX STi
Fav Mod: HKS Hi-Power exhaust
I cut mine from the outside edge(exhaust side) to the heat shield. I had about a 1/4 inch of material left on the diffuser. you can't even tell it's been cut. -----------------------
l l
l heat shield l
__________l l
^cut(solid line) - probably won't be more than 1/4 plastic left
D1SMember is offline   Reply With Quote
Old 07-05-2007, 02:53 PM   #23
damn when I post it messes up the diagram. heat shield should be to the right of solid line
Old 07-05-2007, 02:57 PM   #24
Fav Mod: widebody
ya thats pretty much what mine ended up looking cause i cut little pieces at first and then eventually i just cut it 1/4 inward from the heatshield back. yea you cant tell that its been cut.
Old 07-08-2007, 12:38 PM   #25
Car: 05 Subaru WRX STi
Fav Mod: HKS Carbon Ti exhaust
Your talking about the stock diffuser on the 07 sti right? Just making sure cause I have the HKS carbon Ti exhaust and I want to get the APR Rear Diffuser. I hope my exhaust will still fit with the diffuser on. Anyone have that problem?
Devildog23 is offline   Reply With Quote
Old 07-08-2007, 12:45 PM   #26
Fav Mod: widebody
yea i had to cut a piece off of the stock diffuser to make the carbonti fit. i dont know about the APR call them and ask before you purchase it.
Old 07-08-2007, 01:11 PM   #27
Fav Mod: widebody
Old 07-14-2007, 04:55 PM   #28
Car: 06 STI (now); 04 WRX
Fav Mod: 06 STI
Send a message via AIM to Vikingmoose
A little late to the thread, sorry. Has anyone considered just trying some Kartboy long exhaust hangers to see if it will give the necessary clearance? I am having the same clearance problem with my Fujitsubo PowerGetter and rear diffuser and bought the hangers but havent tried putting them on yet to see if they provide enough clearance. For now, I just took off the diffuser.
Vikingmoose is offline   Reply With Quote
