Old 04-22-2007, 09:49 PM   #1
Car: 04 Subaru WRX STI
Default How do i adjust my e-brake
How do i adjust my ebrake so i dont have to pull it up to my console? there has to be a easy way to do it.. So if anyone knows just let me know.. Thanks guys
Collin is offline   Reply With Quote
Old 04-23-2007, 04:54 PM   #2
Default Re: How do i adjust my e-brake
remove console... Adjust nut... thats about it... spec is 44lb on force for 7 to 8 notches...
TraSTi is offline   Reply With Quote
Old 04-29-2007, 06:34 PM   #3
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
Does the console just pop off like the shifter trim does, or do you have to remove screws? Also, is it the plastic around the e-brake that needs to be removed, or the arm rest area?
Old 05-11-2007, 01:02 PM   #4
I dono about the MYO6STi but on the TR you pop open the center console and pop out two screws, and you will also see two screws just behind the top of the shifter trim. That is all it takes on the TR but I have only been in two 06 STis and never looked at it.
06wrxtracer is offline   Reply With Quote
Old 05-13-2007, 09:46 AM   #5
Car: 94 STI WGN, 93 GF8,
Fav Mod: ACPT Driveshaft & White Brembos
The correct way to do it is to take your rear wheels off, remove your calipers, remove your rotors then there is a little wheel in the brake drum that you spin that adjusts the pads in and out.
snowcrzy is offline   Reply With Quote
Old 05-13-2007, 04:34 PM   #6
No way. Whenever I take my car to Subaru for an oil change, they tighten it up for free while I wait. There's no way they would do all the work you described for free or be able to do it during the half hour it takes to change the oil/ tighten the e-brake.
Old 05-13-2007, 05:34 PM   #7
Car: 06 Subaru WRX STi
Fav Mod: Cobb Xaust!
i used to have this pdf file that explained how to adjust it... if i find it i will post it.
I remember there is one screw that you have to tighten but i have never done it...
oscargarza88 is offline   Reply With Quote
Old 05-16-2007, 10:29 PM   #8
Car: 06 Sti
snowcrazy that's only for Drum brakes! not Disc.. the way the first Reply said is how you do it. by the way another reason your E-brake is high couuld be worn brake pads or Rotors are to thin.. Get those checked out. which will also cause your master cylinder fluid to get low.
effect is offline   Reply With Quote
Old 05-16-2007, 10:52 PM   #9
Car: WRB 06 WRX STI
Fav Mod: Stage 2
My e-brake was weak from the factory... My brakes only have 7k on them so thats not it.. maybe a how to with pics is in order!!
SonicBoom is offline   Reply With Quote
Old 06-17-2007, 01:56 AM   #10
Car: 05sti,05g35,08cbr1k
Fav Mod: track days
snowcrzy is correct. we have rear disc brakes as primary. however our park/emergency brake is drum inside the hat of the rear rotor. go ahead try to pull off that rotor without removing the plug and relaxing the shoes. a exercise in cursing.
lycan is offline   Reply With Quote
Old 03-26-2008, 08:32 PM   #11
Iron Fisted
Fav Mod: Sparco seat
Sorry to bump such an old thread, but does this adjustment just make the "full engagement" point lower down? Does it affect anything when it's all the way released?
I've noticed mine is getting higher and higher as time goes on...
Old 03-27-2008, 06:32 AM   #12
Yes. It makes the hand brake engage sooner on the upward pull. I adjusted mine a few months ago because mine was loose from day one and it made such a difference.
Old 03-27-2008, 09:27 AM   #13
Iron Fisted
^^it doesn't affect the point where the brake releases though, does it? As in, when the lever is all the way down, no matter how tight it is tightened it will be disengaged, correct?
Old 03-27-2008, 01:20 PM   #14
If you over tighten it it will be engaged even when it is fully down. You can easily tell if you over tighten it though as you turn the screw. Just make sure there is some play when the handle is at it's lowest position befor eyou put the housing back together. You want to be able to have little resistance as you start to pull it up and then it should start to feel tight the higher it goes. Pretty self explanatary.
Old 03-28-2008, 06:55 PM   #15
Car: 2006 Subaru WRX STI
Fav Mod: Maddad DP and P&L Catback, stage 2!!!
Send a message via AIM to haroman311
or you can just pop off the rear wheel, remove the little rubber boot on the rear disc, then take a flat bladed screwdriver and adjust it that way.
haroman311 is offline   Reply With Quote
