Old 04-21-2007, 06:08 PM   #1
Car: 04 WRX STi
Fav Mod: Whiteline Everything
Send a message via Yahoo to scotty20bsp
Default wheel stud replacment
any ideas on how to do this mod? I've looked at the scooby mods thread and I tried to install the rears today. I even took off the E-brake shoes for more room. The new studs are 66mm long. They go with a wheel spacer kit I got for auto-X. I'll try the fronts tomorrow.
scotty20bsp is offline   Reply With Quote
Old 04-21-2007, 06:12 PM   #2
Car: 2006 Subaru WRX STI
Fav Mod: Maddad DP and P&L Catback, stage 2!!!
Send a message via AIM to haroman311
Default Re: wheel stud replacment
really isnt that hard just a PITA, i did it on a cold winter day so my hands were freezing, just some tips, dont tighten the bolts down on the tone ring too tight, i snapped one you have to sit for awhile and manuver it around for a bit, i used a extendable magnet that i use at work to reach objects i dropped, just put it into the hole on the hub and kinda magnatized it there and pulled it through. i didnt take off the shoes, i just finagled it around and i got it to go through, just be patient and you will get it.
haroman311 is offline   Reply With Quote
Old 04-21-2007, 09:53 PM   #3
Car: 04 WRX STi
The stock length studs are apiece of cake to put in its the long ones that are hard to do.
Old 05-13-2007, 12:02 PM   #4
Car: 92 Legacy Turbo
Send a message via AIM to Stubaru
For the longer ones, did you have to take the whole assebly apart and redo the bearings or did you cut a hole through the back of the shoe?
Stu
Stubaru is offline   Reply With Quote
Old 05-13-2007, 12:29 PM   #5
Car: 04 WRX STi
I was going to drill a 3/4" hole in the backing plate and then plug it. One friend said it would work another said that moisture and debris would scerw with the abs. What to believe?
Old 05-13-2007, 01:10 PM   #6
I kinda doubt that, still if the hole is plugged then it should be fine.
Stu
