Old 04-14-2007, 06:45 PM   #1
Fav Mod: Starving my STI
Trader Rating: (12)
Default How to adjust gas pedal?
I know there is a thread on how to adjust the brake pedal, but is there any way to adjust the height of a 05 STI gas pedal?
Old 04-15-2007, 04:58 PM   #2
Car: 06 STi WRB
Fav Mod: Snow Tires
I could be wrong but I think its driven by an electric motor from 05-up
ianparcher is offline   Reply With Quote
Old 04-15-2007, 10:44 PM   #3
Yup, drive-by-wire.
volkl23 is offline   Reply With Quote
Old 04-16-2007, 12:07 AM   #4
Trader Rating: (12)
Default Re: How to adjust gas pedal?
I know it's drive by wire, but just wondering if there is still some way to adjust the height and recalibrate the sensor/motor.
Old 04-17-2007, 05:48 AM   #5
Trader Rating: (12)
Anybody? Can the height of the gas pedal on an 05 STI be adjusted?
Old 04-17-2007, 06:39 AM   #6
Car: 06 STi
you can just climb down there and look for your self. I doubt you can adjust the linkages since that'll change the caliberation on the position sensor. However, you might be able to modify the mounting points on the pedal it self to raise or lower the pedal.
gte123v is offline   Reply With Quote
Old 04-17-2007, 10:12 AM   #7
HowTo Contributor
Car: 04 Subaru STI
Fav Mod: More power
I adjusted mine,..not for height,...but for position sideways. I moved mine to the left to make heel-toe'ing easier.
But the pedal assembly is held on with a few 10mm nuts. I also have a Hummer H3,..and the pedals were WAY too close to the drivers seat. On that car I removed the gas pedal and inserted 2 oversized nuts on the top mounting studs (to act as spacers) and reinstalled the pedal assembly. This moved the pedal itself (which is at the bottom) back almost an inch.
You could do the same with washers on the top or bottom mounting points (depending on which way you are trying to move it) until you got it where you wanted. You can also simply remove the assembly (couple 10mm nuts and one electrical connector) and put the pedal arm in a vice and bend the arm a bit to change the height. (That's how I moved mine to the left).
DuckStu is offline   Reply With Quote
Old 04-23-2007, 10:58 AM   #8
Car: 06 STI, sgm
Ah, the vice trick. Certainly a lot cheaper than that $300 PDE pedal set you can get. I stuck my head under the dash and saw that the gas on my 06 has another screw hole to the left of the top mounting bolt, but not on the bottom. So close, so far... I want to move my pedals closer for heel-toe as well.
TreyV is offline   Reply With Quote
Old 08-16-2007, 05:20 PM   #9
Car: 05 WRX STI OBP
Fav Mod: learning how to heel toe
i dont think there is a way to recal it or adjust it if your looking for better response try uprading your ignition sys. or bigger throttle body
Old 08-16-2007, 05:40 PM   #10
Car: '06 STI
Fav Mod: air freshener!!!
Try platform shoes.....
Old 08-16-2007, 05:49 PM   #11
Car: 05 WRX STI OBP
funny
Old 08-31-2007, 08:11 AM   #12
Fav Mod: LS6 and T-56 swap :D
Hmmm... I would love to move mine to the left a bit for easier heel-and-toeing. So do I just take whole thing off and bend it a little? or can this be done with a couple washers?
Rookie84 is offline   Reply With Quote
