Old 04-17-2007, 05:06 AM   #16
Fav Mod: TBE
Default Re: How To: Change your Transmission Fluid (with pics)
Yea I was thinkning about doing that soon. I'll defintely make another write up when I do it if you guys want
Old 04-17-2007, 07:34 AM   #17
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
Thanks for the write up. Reminded me that I'm probably overdue for this.
pt518sti is offline   Reply With Quote
Old 04-26-2007, 08:15 PM   #18
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Why is it that when I told the guys at the Subaru dealership about the two spots to drain the fluid, they had no idea that there were two. They only gave me the washer for the pan and had to special order the other one because they have NEVER stocked it.
importfanatic17 is online now   Reply With Quote
Old 04-28-2007, 04:24 PM   #19
Fav Mod: TBE
Same thing happened to me. The guy had no clue about the other one and had to order it. He said "Well, we do trans fluid changes here all the time and we've never stocked that one before". The guy said they've never even heard about it. Makes you wonder.....
Old 04-29-2007, 07:32 PM   #20
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
Since you fill in only one spot and drain in two spots does that mean that tranny, rear diff and front diff all take the same fluid? And what is the GL-5 rating that quicksilverSTI is talking about?
CenCali07STI is offline   Reply With Quote
Old 04-30-2007, 05:10 AM   #21
Car: 05 CGM WRX STi
Fav Mod: all
To answer your questions...
Tranny and front diff use the same oil pan and both require an oil with a GL-5 rating (see below).
Rear Diff is separate and requires LSD Gear Oil (STi specific) such as found on this page http://www.subaruparts.com/catalog/?section=366
The following excerpt regarding GL-5 rating was taken form the API (American Petroleum Institute) PUBLICATION 1560
"API GL-5
The designation API GL-5 denotes lubricants intended for gears, particularly hypoid (see note) gears, in axles operating under various combinations of high-speed/shock load and low-speed/high-torque conditions.
Note: Frictional requirements for axles equipped with limited-slip differentials are normally defined by the axle manufacturer."
Hopefully this answers your questions and doesn't confuse you more.
speedstyle is offline   Reply With Quote
Old 04-30-2007, 05:35 AM   #22
Fav Mod: TBE
Yea, the front diff and trans share the same oil. The rear diff uses LSD specific oil. Speedstyle pretty much summed it up.
Old 04-30-2007, 04:52 PM   #23
cool thanks. SO should be the same even for an 07 like mine that changed to Torsen style differential rather than helical? Or should I do some research lol.
Old 04-30-2007, 06:58 PM   #24
Car: 05 CGM WRX STi
Fav Mod: all
Research is always a good thing. Everbody seems to have different opinions when it comes to stuff like which fluids to use so I always consult my service and owners manuals before doing anything.
Old 05-01-2007, 09:39 AM   #25
Car: 04 STi - Aspen White
Fav Mod: Cobb Short Shifter
nice write up. i did this not too long ago and a funnel like this makes the filling it a breeze.
Originally Posted by SubyFi
Cool write up.
You need one of these funnels next time:
question: is there any potential problem with having it filled over the full mark? mine is just a little over when cold and i didn't want to try and drain just a tiny bit so i left it and haven't noticed any issues.
jomotopia is offline   Reply With Quote
Old 05-03-2007, 01:28 PM   #26
DirtyImpreza.com
Car: 04 STi, 01 RS
Fav Mod: ACPT CFDS
Send a message via AIM to 409industries
Nice write up, you used my picture from forever ago!
409industries is offline   Reply With Quote
Old 05-04-2007, 12:41 PM   #27
Fav Mod: TBE
Haha I know, I forgot to take a pic of it and I didn't feel like putting the car back up in the air again.
Old 05-09-2007, 12:35 AM   #28
Car: AW 05 WRX STi
Fav Mod: Recaro Racing Seats
Send a message via AIM to JKonquer Send a message via MSN to JKonquer
how often are you suppose to change the tranny fluid and rear diff fluid?
JKonquer is offline   Reply With Quote
Old 05-09-2007, 01:16 AM   #29
Car: 08 STi, SSM
I just go by the suggested intervals in the owners manual.
Old 05-28-2007, 05:54 PM   #30
H4N
Fav Mod: EWG, T 2'S
bump.... for a quick questions... do you read the tranny dip stick when the car is on or off? i came from doing changes on autos and you had to read it while on.
H4N is online now   Reply With Quote
