Old 03-27-2007, 01:23 PM   #1
Car: 05 WRX STI
Exclamation Emergency!! Need To Remove Ecu
HOW TO?? TAKE THE ECU OUT
i really screwed up.. i kicked my acessport out while it was initializng to flash the ecu, and now the car wont start and the AP wont read the ECU.. Called Cobb Tuning and i need to send the ECU to them to get reflashed to stock..
I DONT KNOW HOW TO TAKE THE ECU OUT
but im tryin to do this ASAP..
CAN ANYONE GIVE ME A HOW TO- TAKE THE ECU OUT!!
ud be a life saver
05 sti
mike
rawedge2 is offline   Reply With Quote
Old 03-27-2007, 01:24 PM   #2
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
ECU is under the passgenger side carpet area. You cant miss it.
Old 03-27-2007, 01:28 PM   #3
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
http://turboxs.com/stiupdate.htm
Grab the file "STI UTEC v2.3" from there. Inside is the UTEC install guide. You can follow the part in it which tells you how to remove the ECU. Pictures are included as well.
Sorry to hear about the fried ECU.
kts262 is online now   Reply With Quote
Old 04-24-2007, 10:36 AM   #4
jep
Car: 05 sti
Fav Mod: 23'' chrome spinnaaazz
Default Re: Emergency!! Need To Remove Ecu
Originally Posted by Collin
Send it into Cobb and they should warranty it. Dont tell them you kicked it out. tell them that half way during the loading process it froze up and then it said cannot communicate with ECU. Then you wont have to pay anything.
Good luck
jep is offline   Reply With Quote
Old 04-24-2007, 10:47 AM   #5
Car: 2006 STI BLUE
Fav Mod: Fp20g and protune
yeah lie .. that will get u far in life .. he knew he messed up and will pay for it ..
Old 04-27-2007, 10:44 AM   #6
Car: 07 CGM STi
Fav Mod: For those 13 seconds or less, I'm free!
Send a message via AIM to Acejam2k
disconnect test connectors, try starting car, plug connectors back in, try reading ECU..
my AP "froze" kind of once. I know its highly reccomend not to unplug it, but I did anyways, and then just did the above, and worked fine for me.
Acejam2k is offline   Reply With Quote
Old 08-13-2007, 12:29 PM   #7
Car: 05 scooby sti
Fav Mod: project Mu pads
Send a message via AIM to brutalsti
reset the factoy ecu then put the car in test mode and try again it should work
brutalsti is offline   Reply With Quote
Old 08-13-2007, 04:08 PM   #8
Car: 05 STi - Black
Fav Mod: No Lien
did you screw up using a v1 or v2 ap? Because there is a fix for a v2 screwup
1) plug in test connectors(fans will not come on if ecu is down)
2) plug in AP and choose uninstall. then you will be prompted to confirm and click OK and the AP will uninstall, save and revert back to stock mode. (mine did not work the 1st time i tried to uninstall it so i called cobb and he said just do the process over again starting with turning the car off and sure enough it worked)
3) turn car off and unplug AP(if uninstall is complete, your fans will come on)
4) plug in AP and turn key to on
5) install AP again and choose your preferred map.
Old 08-13-2007, 06:01 PM   #9
Car: 07 Subaru WRX STi
Fav Mod: ALL MODS
Very easy to take out. Just lift up the carpet on passengers side floorboard, you should see a square box with a few clips and alot of wires going to them. Pull the the clips out and unbolt ECU. But make sure battery is disconnected just in case ECU is not fried! I have seen many cases of frying an ECU b/c battery was still connected and giving power! Sorry bout ur ECU and good luck.
12SECSORLESS is offline   Reply With Quote
