Old 03-23-2007, 04:53 AM   #1
Car: 05 STI for Sale
Fav Mod: Coilovers
Default Need help: samco inlet
I was told i dont need to remove the manifold for the samco inlet. IF so can some please tell me how i would go about removing this without taking off the manifold. thanks
godfather2112 is offline   Reply With Quote
Old 04-03-2007, 05:16 AM   #2
Car: SGM 06 sti
Fav Mod: gt30R + SMC meth kit
Trader Rating: (13)
dame man that's PITA I did that without removing manifold but that was the worst time ever. I sprayed it with WD40 and then I spent 4 h to put it on , but I did it
pawlooo is offline   Reply With Quote
Old 06-14-2007, 09:43 PM   #3
Default Re: Need help: samco inlet
any tips on removing the stock... I stock with the stock and broke one of the pieces already so cant just hook it back up
TraSTi is offline   Reply With Quote
Old 06-14-2007, 09:52 PM   #4
Car: 06 WRX STI
Fav Mod: Invidia G200
I would recommend using a spray bottle with dishsoap and water. It's better than any other lubricant because it will not deteriorate the silicone and it dries. Second recommendation is take your time. A set of oring picks will help out tremendously. If you're putting on a silicone inlet i would HIGHLY RECOMMMEND PUTTING A T-BOLT CLAMP ON THE TURBO. Also before you begin take off ALL of the aluminum pieces from inside the silicone pieces. Good luck...
boataholic is offline   Reply With Quote
Old 06-15-2007, 09:36 AM   #5
Car: 02 WRX + 2many mods
Fav Mod: 16g pnp
Send a message via AIM to Chandy70
Best lubricant is KY gelly we all know that!
But when your doing this mod Honestly PAM cooking spray was much better then WD40!
Reason is .. It smells better and wont dry out & washes off easily with no marks.
Chuck
Chandy70 is offline   Reply With Quote
Old 06-22-2007, 09:54 AM   #6
Fav Mod: Perrin 30r Kit
yeah installing my inlet was a big PITA...just get prepared to try to get that thing in there with some difficulty...there isnt a lot of room to play with it, which is why its hard. just get that sucker lubricated and it shouldnt be too bad, i didnt do that and i paid for it.
and to get the stock one out, i dont see how you can unless you break off the pieces sticking off of it. its not very flexible.
