Old 03-19-2007, 07:44 PM   #1
Car: 04 sti
Fav Mod: STI radiator hoses
Default how to crush sti bpv?
wanted to find out how to crush the sti bpv.... my friend is going to boost more and herd that this helps him out.... thanks
325boi is offline   Reply With Quote
Old 03-20-2007, 06:59 AM   #2
Car: Slow 05 STi
Fav Mod: Loping Idle
Hammer plus a 12 or 14mm socket. Or a clamp plus socket. You will need a micrometer to measure how much you crush.
Old 03-20-2007, 07:04 PM   #3
Car: 04 sti
but what part do you crush... dose anyone have a wright up on this?
Old 03-21-2007, 05:10 AM   #4
Car: 05' STi
Fav Mod: JDM Fogs
how much boost is he going to be running through the stock BPV.
I have heard good an bad things about crushed bpv's.
This brings back mermory's of the DSM guys, this seems to be a common mod among 1st gen DSM's.
Old 03-21-2007, 06:40 AM   #5
Fav Mod: Driving School / Trunk swap (no attention ftw)
Here's the write up: check out a forge recirculating valve...
mgsm666 is offline   Reply With Quote
Old 03-21-2007, 12:32 PM   #6
crush the golden part... how much?? I would depend on boost but have any ball park numbers
TraSTi is offline   Reply With Quote
Old 03-21-2007, 02:33 PM   #7
nulla poena sine lege
Car: '06 Works GP
Originally Posted by mgsm666
Here's the write up: check out an APS BOV
Fixed
QuickSilverSTi is offline   Reply With Quote
Old 03-21-2007, 03:00 PM   #8
Car: 04 sti
around 22-24 pounds.... ya i told him to get a forge recirculating valve but he wants to keep the stock one
Old 03-22-2007, 05:52 AM   #9
Car: 05' STi
Fav Mod: JDM Fogs
I would think the stock BPV is good to hold 22-24psi. I think around 26 is there he may want to head another direction. Mind hold 21psi with no problem.
I'm curious to see what others are running with stock bpv.
Old 03-22-2007, 06:16 AM   #10
Moderator & ECU Tech
Fav Mod: mo boostaz
http://www.bescaredracing.com/sti/in...v/stock/crush/
t
Old 03-22-2007, 10:21 AM   #11
Car: 04 sti
^ thanks.... but what dose it actualy do to the bpv? just wondering....
Old 03-22-2007, 10:37 AM   #12
Car: 05' STi
Fav Mod: JDM Fogs
when you crush the top it compress's the spring more
With the spring requiring more pressure to move it; it takes more in order for the diaphram in there to open up.
Old 03-22-2007, 12:39 PM   #13
Car: 04 sti
now i get it.... what if your on stock boost?
Old 03-22-2007, 06:22 PM   #14
Car: 05' STi
Fav Mod: JDM Fogs
don't know for sure. I am on 19psi with my bpv stock and have no problems.
I can't say for sure this isn't really my area of expertise.
Old 05-14-2007, 10:03 PM   #15
Car: 04 WRB STI
Fav Mod: vf36
Default Re: how to crush sti bpv?
I used a 3/8" ratchet extension with the female side down and a rubber mallet. Just a couple of light blows in the center of the cap should do it.
calisti is offline   Reply With Quote
