Old 03-07-2007, 02:23 PM   #1
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
Default help mwith Defis almost done!!!!
I installed the Defis EGT/BOOST and OP. Everything went smooth until the time to start the car. NOTHING HAPPENS, I tapped the clock harness as follow:
Black on Black
White on white(the one on the clock has thin a red stripe and says ILL)
Orange on Orange(says ACC ON on the clock)
Red (with the blue with a orange stripe)
Everything went nice specially the EGT tap that was my main concern.
I connected the OP harness and everything but I am going to wait to intall the GREDDY adapter, so I put a stap to the connector well secure in the engine bay, but is not connected to the sensor.
The gauges dont do nothing, nothing, I checked the wire taps and are well connected.
Any ideas???
BBBsti LTD is offline   Reply With Quote
Old 03-07-2007, 02:26 PM   #2
Is Scared Of Kevin...
i wouldn't tap the clock first of alll use the back of the radio.....also make sure the fuse in the power wire is good also
MKTURBO is offline   Reply With Quote
Old 03-07-2007, 02:30 PM   #3
Car: 2007 STi LTD
What is wrong with the clock, I thought that this is the ideal location.
Old 03-07-2007, 06:07 PM   #4
Car: 2007 STi LTD
Now is working after I used the radio harness.
Is not the T fitting that comes with the Defis too small to be connected at the BOV.
I bought a T fron AUTOZONE without the restrictor and the PSI in 4th went to 16!!!! too high???
Old 03-16-2007, 01:17 PM   #5
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
pics?
TAPOUT is offline   Reply With Quote
Old 03-17-2007, 12:33 PM   #6
Car: 07 WRX STi
Tapout. Do I need to do a step by step with you? I have my defi guage now, if you can come to baltimore we can knock this out on Thursday.
Ooie is offline   Reply With Quote
