Old 03-05-2007, 04:39 PM   #1
Car: 2004 HarmanMotive St
Default How to tie down vehicle to open trailer?
Hi All,
I'll be taking my STi to Summit Point next month for my 1st track event with it, and was wondering if anyone has tips on tying down the vehicle. I have an open aluminum trailer with 4 D-rings, trailer bed is completely flat and there is no gap in the middle. Granted, I haven't really looked underneath for any hooks except for the rear towhook I had to take out when I installed the diffuser, but the rear I usually just strap the rims. Looking for tips on tying down the front of the vehicle. Thanks.
NSX13 is offline   Reply With Quote
Old 03-05-2007, 04:42 PM   #2
Car: 05 Subaru WRX STi
I've been doing research on auto transports and it looks like the pros strap by the tires or wheels. The crappy ones strap or chain by suspension components which can lead to lots of damage.
rasetsu is offline   Reply With Quote
Old 03-06-2007, 04:53 AM   #3
Fav Mod: Sways
There are 4 anchor points under my car (2 in the front behind the wheels, and 2 in the back next to the frame. These are the ones I use inside my enclosed trailer and works fine. I assume that Subaru put them there to tie the car down on the boat when they floated it over from Japan. Mine a 05 and I'm not sure about a 04 though.
yellowducman is offline   Reply With Quote
Old 03-06-2007, 07:43 AM   #4
Default Tying down car on trailer.
Thanks! I will take a look for these points when I do all the fluids and change out the brakepads.
Old 03-07-2007, 03:24 AM   #5
Car: 05 Subaru CGM STi
Send a message via AIM to molehill84
Good luck man...All I know is that you should obviously stay away from the lateral links...When my STi was delivered to my house by flat bed about a month ago the transporter had hooked onto the lateral links and he snapped one in half...
molehill84 is offline   Reply With Quote
Old 03-07-2007, 07:04 AM   #6
Car: Something Bloody
Fav Mod: E85
or you can do alot of bungee chords! lol, one said to put it on the hooks where they tow which is a good idea. i was thinking on the axle or something, though i have no experience, that to me makes the best sense.
Albanianimpreza is offline   Reply With Quote
Old 03-07-2007, 07:06 AM   #7
Poor Speed Racer
Car: 96 328
+12345
you cant miss the hooks if you look for them. They are on every corner of the car, and I've used them on more than one STi and never had a problem.
when are you at summit?
Old 03-07-2007, 07:16 AM   #8
Fav Mod: LoL
Yeah just make sure you leave the car in neutral if its a standard
Apro1 is offline   Reply With Quote
Old 03-07-2007, 10:28 AM   #9
Fav Mod: Sways
I've heard that but have never done it. I always leave the car in gear and the parking brake on on the way to the track and just leave it in gear for the ride home (rear rotors usually are still hot). I've never had a problem and I don't think the car rocks back and forth.
Old 03-07-2007, 11:12 AM   #10
Poor Speed Racer
Car: 96 328
I never put a hot car up on the trailer, i always let it cool down before i strap it up. If you use the E-brake as well as leaving it in gear, thats ok, but for cars with no e-brake, i never ever leave it in gear. I figure transmissions are expensive.. and i dont want to have to pay to fix one.
Old 03-07-2007, 01:54 PM   #11
Fav Mod: Sways
I realize that it's bad for a car to rock back and forth against the gear lash of the transmission but honestly if my car is strapped down so loose that the car can shift back and forth I'm going to go back and re strap it. To me, leaving the car in gear is an extra security against braking a strap.
I agree that the car should be cool before loading it up on a trailer but I usually am ready to load up and get out of dodge after my last session and don't want to wait for the car to cool down before loading.
Old 03-07-2007, 02:01 PM   #12
Poor Speed Racer
Car: 96 328
agreed about leaving after the last session! but i normally have a metric fook ton of gear that goes into the truck, so i load that up first.
Old 03-07-2007, 02:11 PM   #13
Car: Blue 04 Subaru WRX
Fav Mod: I love my TBE because the sound of the STi engine is like nothing I have ever heard.
Send a message via AIM to ur2s2pid
I drive a tow truck for a living and I leave all of the cars in gear just in case any of the chains do snap. You can tie the car down at all four courners with the wheel straps but you can also look underneath the car and you will see 2-3" oval cut outs at every corner those are the holes that are built into the car for straping it down with chains. If you do strap it like that make sure that you have enough room between the chains and the front bumber so that if the car bounces during transport you wont crack your lip. (sorry got into that one first thread I could give usfull knowledge in )
ur2s2pid is offline   Reply With Quote
Old 03-07-2007, 05:53 PM   #14
Fav Mod: LoL
That's not the transmission you should worry about or your brakes. I seen it before, more than once, cars arriving on trailers with their timing belt slipped as much as 6 teeth. And they all look very tightly tied down.
Old 03-08-2007, 03:36 AM   #15
Default Summit Point
I'll be there 4/16 and 4/17 for the NJ Chapter BMWCCA Advanced Driving School and Instructor Training School. Will be my first time at this track - heard lots of great things about it.
+12345
