Old 03-22-2007, 04:41 PM   #16
Car: '08 BMW 135i
Originally Posted by snorky
i have these: harbor freight 3 ton jack stands
they have Vs cut into them for the pinch welds/tabs. it straddles the pinch weld just like the emergency jack. i stored my car over the winter with these and use them every time i put my car on stands. pinch welds are in perfect condition.
$20 and they are well built. harbor freight is hit or miss. these are a hit, imo.
I use the Harbor Freight jack stands as well as they have a deeper groove cut in them then the Sears jackstands that were available here.
MadMan77 is offline   Reply With Quote
Old 03-22-2007, 04:56 PM   #17
nulla poena sine lege
Originally Posted by Pitcherman
^^^ yeah, you guys act like bending those pinch welds is actually going to affect the car at all.
Nah, it just worked out that I had the jack stands with the V.
QuickSilverSTi is offline   Reply With Quote
Old 03-22-2007, 06:47 PM   #18
If in doubt, flat out
Trader Rating: (23)
it may, it may not. it's nice to be able to use the jack that came with my car in an emergency if i ever need it.
Old 04-17-2007, 10:37 AM   #19
Car: 08 STi, SSM
Default Re: jack stand points
You mean the "widow maker" jacks God, I remember using the oem VW jack on a Fox once to change a tire, never been more scared while working on a car.
Old 04-17-2007, 12:01 PM   #20
Car: 06 wrx ltd vf34
Fav Mod: JTAG
I've heard that using subframe for jack points is not a good idea. it will damage the subframe. location rite behind the subframe will be a better spot.
bzbuzz is offline   Reply With Quote
Old 04-17-2007, 12:26 PM   #21
Trader Rating: (23)
i'm not saying it's ok to get under that car using the supplied jack. but on that note, if you can make the car fall on flat, solid surface, with the wheels staked, using the supplied jack, you need help. the supplied jack is very solid compared to the ones supplied with previous cars i've owned or seen.
Old 04-21-2007, 10:44 PM   #22
Fav Mod: jailbreak
up front i go right behind the sub frame, in the rear... i forget i think i use the pinch rail
Old 04-18-2008, 12:50 PM   #23
Can you guys check my jacking points?
same spot for passenger side
empfl is offline   Reply With Quote
Old 04-18-2008, 02:05 PM   #24
Trader Rating: (23)
you can jack it up there. why not just use that jack up plate up front and the rear differential?
Old 04-18-2008, 02:09 PM   #25
Car: 08 STi, SSM
I'd rather jack front, then the rear instead of lifting each side to get it on stands. The way my jack stand cradles are oriented at the pinch welds makes it much more stable to go front then rear when lifting.
Old 04-18-2008, 02:13 PM   #26
Trader Rating: (23)
word.
Old 04-18-2008, 02:54 PM   #27
my jack isnt that long, and the lip doesn't help, so i have barely any leverage for the jack.
i found the rear jack stand points, but there aren't any identical ones to the front.. i was told not to use the pinch welds as a jack stand, but as a jack point.. any help on the front jack stand points?
thanks.
Old 04-19-2008, 02:24 AM   #28
Car: 08 STi, SSM
The front pinch welds are perfect for jack stand points, I just used them last weekend. PERFECT. Get jack stands with a nice deep cradle. Drive up on bricks or 2x4s to get clearance for your jack, get creative. This really isn't all that difficult.
Old 04-19-2008, 10:15 AM   #29
Iron Fisted
Fav Mod: Sparco seat
Regarding jack stand points, I use the pinch welds. I used a hammer to "gently" bend them down so now I don't have to worry about them collapsing when I'm under there. If your pinch welds are bent before you get under there, you have NOTHING to worry about. I really don't see why people are so against putting stands under bent ones.
Also, FYI there is a much longer thread on this in the sticky. You many find a few more opinions there as well.
Old 06-08-2008, 07:21 AM   #30
Car: WRB/Gold 05 STi
Fav Mod: STi Short Throw
These look like they might work well. The cut out seems large enough that it wont affect the pinch weld.
CanuckSTi is offline   Reply With Quote
