Old 02-10-2007, 08:54 AM   #1
Car: Autox solo2
Fav Mod: More high-test gas.
Default Find obd II port
Is the obd port a unique color and the same fixed place or is a wire
with plastic end cap/plug that looks like every other one under the dash ?
squid is offline   Reply With Quote
Old 02-12-2007, 02:30 AM   #2
Car: 08 STi, SSM
It's a big multi-pin port in the plastic shrouding pretty much directly under the steering column. But I'm not quite sure what you're asking.
Old 02-12-2007, 03:13 PM   #3
Car: Autox solo2
There's several of those white-gray plastic plugs with a half dozen wires going
into them under the steering column. None look loose, they are all secured or
attached.
I do not want to unplug the cruise control or other wires by mistake.
Old 02-12-2007, 03:16 PM   #4
Car: WRB GDF-E
Fav Mod: Majin
You can plug into the OBDII without unplugging anything, all while sitting the drivers seat. Its near where your right knee would be.
EDIT: Its actually closer to your left knee.
Old 02-12-2007, 03:23 PM   #5
abracious
Fav Mod: Track time
it is NOT under the dash, it is in the dash, albeit in about the lowest part possible. hard to miss if you get low and look up.
Old 02-14-2007, 09:39 PM   #6
Car: Autox solo2
Indeed. Most people never notice the coin drawer, fewer people would
notice this socket, it is indeed part of the dash I can see if I lie on my
back on the ground (obSnowAngel today).
Thanks, I'm not running my ScanGaugeII.
Old 02-22-2007, 05:16 PM   #7
Car: 05 WRX STi (wrb/gold
Fav Mod: Utec
weird
nasti05 is offline   Reply With Quote
Old 08-16-2007, 05:29 PM   #8
Car: 05 WRX STI OBP
Fav Mod: learning how to heel toe
Default Re: Find obd II port
no question is stupid but there is that one time
Old 09-11-2007, 12:43 AM   #9
Car: BLOBEYE SYNDICATE ST
Fav Mod: N-E thing JDM
So is this obd II port that same as being called the obd II diagnostic connector where you could plug the greddy infometer and obd II scanner??Getting kinda confused.Sorry just one of those days where my thinking if totally off!!
twilight_samurai is offline   Reply With Quote
