Old 02-03-2007, 12:19 PM   #1
Car: silvr WX STi
Fav Mod: Cobb Accesport
Default How to install sub into factory head unit
hi i am new to the sit and just got an STI i am trying to put my subwoofer into it from my old one. I was wondering how to tie it into the stock head unit??
Cereal13 is offline   Reply With Quote
Old 02-03-2007, 12:23 PM   #2
Car: 2005 OBP STi
Fav Mod: CBE
i think you just tap into the rear speakers to get power to the sub. then just install the amp as usual (to the battery, remote wire to a 12 volt source)
johnlude85 is offline   Reply With Quote
Old 02-03-2007, 12:26 PM   #3
Car: silvr WX STi
what about the rca cables do i not use them...i have found the wiring diagram for the 05 stis but i wasnt sure if i needed the rca cables
Old 02-04-2007, 12:59 AM   #4
Car: '07 Sti Limited
Fav Mod: oem short shifter
bump, i would like to know also.
SubieGsR is offline   Reply With Quote
Old 02-04-2007, 03:36 AM   #5
Car: 2006 Siliver STi
Fav Mod: Recaro's
what you need is a line out converter. what it does is it tapes into a regu. ab channel, and convertes to a d channel by just making it a line out thats not pre-amped. your mids run off a ab channel, and a sub needs a d channel. your ab channel is pre-amped from the deck, and a d channel(from a aftermarket deck) is not. thats why its in the back of most aftermarket deck's in order to hook up rca's to utilize and incorprate a aftermarket sub. they usualy run about 8 to 20 bucks, depends how much you want to spend. ebay is a good place to get one. and just follow the instructions to install it. its very ez. hope this helps you man. if you need more help, just pm me.
rekedevoate is offline   Reply With Quote
Old 02-08-2007, 05:27 PM   #6
Cereal13,
Just in case you (or someone even less knowledgeable about car audio) didn't understood that last post, so I'll I explain it in anti-cliff note mode.
Most factory head units only have a single harness connection in the back. This harness provides power to the head unit and signal output to the speakers. The speaker outputs are called "speaker-level" or "high-level" output. Pre-amp out puts are called "low-level." This is where RCA cables are used, but pre-amp outputs are not on most factoru head units.
The head unit has its own amplifier, but as most of us know, it is not powerful enough to get the sound and feel we desire from a subwoofer. Therefore we need an external amplifier. Amps can have both high-level and low-level input. If it has high-level input you can simply connect a wire to rear speaker wires and run them to the amplifier. If you the amp only has low-level inputs, then you will need a high-level/low-level converter, similar to the one pictured HERE.
There is a definate down side to this sort of installation. For one, you are converting high to low, which isn't the best for sound quality, but since most people will do this just for bass, it's not big deal. The other thing is that your subwoofer volume and sound will be directly effected by your tone, balance, and fade setting on the head unit.
metoo is offline   Reply With Quote
Old 02-22-2007, 05:18 PM   #7
Car: 05 WRX STi (wrb/gold
Fav Mod: Utec
scosche is horrible
nasti05 is offline   Reply With Quote
