Old 03-30-2007, 06:13 PM   #16
Car: 05 Subaru WRX STi
Fav Mod: 93 Octane!!!!!
Send a message via AIM to Endless_STi
Originally Posted by filbert
Here's my DIY on the staticX grounding kit:
http://www.filtsai.com/sti/grounding_kit/index.php
Wow, this is a good write up. Even a dummy like me could follow these directions .
Endless_STi is offline   Reply With Quote
Old 10-28-2007, 01:12 AM   #17
07 OBP STi Owner
Car: 07 OBP WRX STi
Fav Mod: The ones I install myself!
Default Re: ground kit...please help
Actually, the grounding kit will smooth out both your horsepower and torque curves if you run the car on a dyno. But as far as gaining more power, negligable and not worth the money for a must do mod on new cars. If you are going to run a big stereo system in your car they can be beneficial then too.
Rasz's STi is offline   Reply With Quote
Old 11-06-2007, 03:14 PM   #18
Car: 2006 Subie STi
Fav Mod: Turbo-back exhaust
Send a message via AIM to FastieMagee06
I just made my own kit out of 5Ga cable. Theres an install on a STi in last months Sport Compact Car ( I think that was the Magazine). It gained -2Hp and +7 Ftlb Tq... How reliable are the numbers... I dont know. I gained about half a volt on the voltmeter, the car seems to rev up better. No clue on the power gain, if any. This seems like a mod that sounds good on paper but, maybe money can be spent other places. Also... another good article on installing a relay and thicker wire on your fuel pump in Turbo this month (I think... LOL)
FastieMagee06 is offline   Reply With Quote
Old 11-06-2007, 03:20 PM   #19
Teh Other White Meat
Trader Rating: (21)
it lost hp?
Old 11-06-2007, 04:06 PM   #20
Muller Chevrolet
Fav Mod: fp green
you can't dyno a ground kit, it's not going to change anything and dyno plots fluctuate in any form.
Old 11-10-2007, 06:53 AM   #21
Car: 2006 Subie STi
If you Dyno your car then add a part and it has a positive or negative affect you'd be able to see if you makes power right? Lost HP for a gain in TQ
Old 11-13-2007, 06:45 AM   #22
Fav Mod: jailbreak
i thought the tuner did that... i had a ground kit on my car. it caused my car to throw all kinds of crazy ass CELs that where for a 07 when i loaded on my AP base map. took it off, and BAM, all cels went away. turned out to be cuz it was loose at the battery, but it really didn't do anything for me besides look kind of cool
Old 11-13-2007, 02:22 PM   #23
Car: 06' CGM STI
Fav Mod: Rustoleum Flat Black
I've seen SRT-4's dyno plots improve from grounding kits. But, dyno plots always fluctuate all over the place so...
With all of the electronics in our cars. A good ground cannot hurt at all though. You won't see a quality computer or other electronic devices without a good ground. You also won't see quality high-voltage electrical circuits without a ground...so why not?
grambo is online now   Reply With Quote
Old 11-13-2007, 05:03 PM   #24
Car: 2006 Subie STi
I figure it cant hurt improving on your cars little 12Ga. ground wires. If you compare it to a car stereo would you use the same 12Ga. ground wire for your amp? It draws more amps but the bigger the better.
Old 11-13-2007, 08:00 PM   #25
Fav Mod: jailbreak
it can'rt hurt, but every tuner i know makes fun of them
Old 11-17-2007, 04:09 AM   #26
Fav Mod: Peter Solberg Autographed my STI
I did it when I had nothing else to do on a weekend. I saw the HKS Circle the Earth system and thought it was ridiculous for a grounding system to cost that much. I went to Best Buy and picked up everything I needed for about $30 and made it up myself. If anyone is interested in this, Go to a Stereo shop or someplace like Best Buy or Circuit City and pick out a length of wire. You pick the wire and guage size you like. Monster Cable looks good and 30' of cable is plenty. I ran a length down to ground my transmission so that will take up a little more wire. Then pick yourself up some connectors and some shrink wrap. Solder your connections and shrinkwrap them so they don't look ametuer. Easy job and kind of fun if you have the spare time and $30 to spend. The cost of this mod is up to you and depends on what you want it to look like. Just don't buy a commercial brand
EuroScuby is offline   Reply With Quote
Old 11-19-2007, 06:22 AM   #27
Car: 06' CGM STI
I have purchased a roll of 4/0 AWG welding cable wire for a grounding system. Its super flexible, plain black, and is super conductive.
Old 11-19-2007, 06:58 AM   #28
Car: 00 Legacy GT LTD
Fav Mod: Projectors.
4/0 Cable? As in "Four Awt"? That stuff is massive!
blk rex is offline   Reply With Quote
Old 11-19-2007, 07:03 AM   #29
Car: 06' CGM STI
It is definately pretty huge. It'll be good for the marger items like the block, tranny, etc.
Plus, with my discount at the parts-house, it was practically free. And the connectors were free.
