Old 12-02-2006, 08:54 PM   #16
Car: 05 CGM STI on 57F br
Fav Mod: stage 2
incredible write up, this is an awesome mod to document. Now I have to keep an eye out for a set of v9 seats... Black Spec C's please. I would assume the process is exactly the same.
Old 12-02-2006, 09:00 PM   #17
Friendlys Suby
Fav Mod: M&J Modified
very cool write-up
Old 12-02-2006, 09:17 PM   #18
Del
IWSTI Club Level 1
Car: 2003 WRB WRX
Fav Mod: Multiquote
Originally Posted by Freddie32001
The whole purpose of this mode is to retain the JDM Seat backs which have the bolsters closer together for a much snugger fit on your waist. The JDM Cover is glued to the seat foam. If you compare both covers, you will discover that they are very different.
O I C.
Del is offline   Reply With Quote
Old 12-03-2006, 07:18 PM   #19
So, how do you trim the excess foam away from the jdm seat if the cover is over it?
docwyte is offline   Reply With Quote
Old 12-03-2006, 07:21 PM   #20
Wheel33tist Whore
you remove the cover.
T3h_Clap is online now   Reply With Quote
Old 12-03-2006, 07:31 PM   #21
He says the JDM cover is glued to the foam.
Old 12-03-2006, 07:50 PM   #22
Car: OBP 06 WRX STI
Trader Rating: (44)
To clear things up.....just the front portion of the cover is glued to the foam, the sides are not. You are able to access the side foam from the opening from the bottom.
Freddie32001 is offline   Reply With Quote
Old 12-04-2006, 10:58 AM   #23
Car: WRB GDF-E
Fav Mod: Majin
I dont think this was directly answered, so ill ask. Are the seat frames different or is it just the seat covers? re-worded-Will the jdm seat cover fit over the USDM seat frame and provide the bolstering we long for?
Old 12-04-2006, 12:41 PM   #24
Car: OBP 06 WRX STI
Trader Rating: (44)
Although both seat frames are very similar, the bolster supports on the USDM seats are farther appart and don't align exactly with the JDM Seat foam. So the USDM seat fram will not fit the JDM Seat cover. (I tried this first, as it seemed to be the easier way to complete the mod)
In addition I wanted to keep the USDM Seat Back and base together so it could be easier sold. Someone with a WRX could easily transfer their air bags to the STI Seats and it would be a direct bolt on.
Old 12-04-2006, 02:37 PM   #25
one of the best write-ups ever. I would love to do this.
BrigadoonB is offline   Reply With Quote
Old 12-04-2006, 03:34 PM   #26
Car: WRB GDF-E
Fav Mod: Majin
So the foam and frame are both different, but by how much? I am just kinda thinking out loud, because I have a metal work/fabrication history and I just really dont want to drop a grand+ on seats and then have to do all this work to them...
Is the lumbar any better in the JDM? The USDM has terrible lumbar support and is my main gripe about these seats...
Old 12-05-2006, 12:34 PM   #27
Car: OBP 06 WRX STI
Trader Rating: (44)
The frames are very similar exept the USDM frame is two inches wider. I suppose you could pull off the covers from you seats and fabricate a different side bolster bracket and weld them in so that it would push your side bolsters closer together....this would also make a great How-To.
My ultimate goal for this mod was to have a more comfortable and better fitting seat while keeping the stock function and appearance. After sitting in a buddy's car with these seats, I was immediately sold!!! I did not want to go with a fixed back aftermarket seat although the ones I tried felt really good and comfortable. Not to mention, I also recouped over half my cost selling the USDM front seats with air bags removed) along with the JDM door panels and rear seats. (I bought the complete JDM set from WorldOne. So in all actuallity, I only spent $700 on this mod and I am very happy. I think it was well worth the effort!!!!
In my opinion...YES YES YES these seats are definitely better than the USDM seats!!!
I was all over the place during spirited cornering and I found myself using my left leg braced against the door pannel and putting a death grip on the steering wheel to keep my self from moving from side to side. The JDM Seats greatly reduced the effort to stay in place.
I think the lumbar support seemed pretty bad on the USDM seat because of the side bulsters being so far appart. The JDM seats side bulsters are a full two inches closer to each other making lower back/lumbar support much better. I also noticed that my upper body and shoulders are set further back/deeper into the seat back making the lower/lumbar much better.
I went on a three hour road trip this past weekend, I can say that it was a very comfortable trip. On previous trips with the USDM Seats, I found my self constanly changing the seat back position in an effort to stay comfortable.
I was actually going to go with a high quality aftermaket reclining or fixed back seats, but after figuring the cost of two high quality seats (recaro, sparco, bride, corbeau, ect...) sliding rails and mounting brackets the price was a little over $1000 a seat.
So all in all, I saved money, have better fitting seats, still have side air bags and it all looks OEM. I am very satisfied!!!!
Old 12-11-2006, 10:20 AM   #28
Car: 06 white STi
Fav Mod: Prodrive CAI, REAL V-Limited Lip
so now your jdm seats have american (left hand side) drivers side height adjustability too?
Impretzle is offline   Reply With Quote
Old 12-11-2006, 12:33 PM   #29
Car: OBP 06 WRX STI
Trader Rating: (44)
Yes,
Both sides are now height adjustable!!!!
Old 01-02-2007, 04:01 PM   #30
Car: PSM '04 STi
Fav Mod: 6pt harness
Nothing goes together quite like beer and explosives! Nice job!
nero9 is online now   Reply With Quote
