Old 09-25-2006, 05:25 PM   #1
Banned
Fav Mod: knowledge
Send a message via AIM to Guest_1u53r
Exclamation HowTo: 4 wheel alignment (string method for toe and thrust)
find it on nasioc instead
Guest_1u53r is offline   Reply With Quote
Old 09-25-2006, 05:26 PM   #2
Banned
Fav Mod: knowledge
Old 09-25-2006, 05:27 PM   #3
Banned
Fav Mod: knowledge
find it on nasioc instead.
Old 09-25-2006, 11:38 PM   #4
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
Nice writh up i did the same a couple of times on other cars. what did you use to hold the steering wheel. BTW you got too much time on your hands
Old 10-08-2006, 02:48 PM   #5
Nick, nice d00d! Am I to assume that this is almost as accurate as the alignment machine?
OT- Why does your post count say 100?? LOL
STEye is offline   Reply With Quote
Old 10-08-2006, 03:01 PM   #6
Banned
Fav Mod: knowledge
it's a coup against postwhoring.
The accuracy of any alignment is limited by the person making the adjustments - how willing are you to dial things in to micro-precision?
I feel confident that I could get a much more precise and accurate alignment than a normal alignment shop, mainly because I am more willing to go the extra mile on my car.
Old 10-08-2006, 06:06 PM   #7
Car: Zohsex
Fav Mod: 295 rears
+1 and awesome write up bud!! when i got my car aligned i was standing out there when they did it and the guy was like "that's pretty close and you'll never feel that small of a difference" i was like uhhhh so good write up i'll most def. use this post to do it myself, how about adjusting the camber, anything on that? i'd like to do my camber and THEN use this post to correct the toe
thanks again
kessler89 is offline   Reply With Quote
Old 10-08-2006, 06:08 PM   #8
Banned
Fav Mod: knowledge
I have been letting a camber howto simmer on the brain for awhile. It requires a lot more diligence because it is very easy to use a camber gauge, get a number, and be convinced that the number you got is correct, when in fact it will likely have large amounts of error.
Old 10-08-2006, 06:13 PM   #9
Car: Zohsex
Fav Mod: 295 rears
good to hear, i'll keep an eye out for if/when you put it on the board, i like to do everyhting myself, that way i know it's done right, i'm sure others can relate, i feel helpless when i need to get my car aligned cause i cant do it myself, you know the feeling..... waching some moron slap a set of laser heads onto your BBS's grrrrrrrr
Old 10-09-2006, 07:02 AM   #10
Car: 06 subaru wrx sti
Fav Mod: royal purple
Nhluhr
disturbed1 is offline   Reply With Quote
Old 10-09-2006, 09:52 PM   #11
Yeah I thought I was getting a good alignment. But in using this string method I was able to find problems with the alignment. Nick is definately part of the l33t crew, thanks buddy!
Old 11-03-2006, 03:45 PM   #12
Fav Mod: jailbreak
very nice. i actually prefer this over machines (former alignment guy/auto tech) the machines are so easy to get a messed up reading on. they are ok ,but it's pretty hard to get set up right,and alot of techs don't do it .
Old 11-11-2006, 08:37 AM   #13
Has anyone verified the track width (or more importantly, the relative difference in track widths) in the STI? OE measurements seem unreliable, but even if they were reliable, Subaru is still rounding to the nearest tenth of an inch.
The 2007 STI type UK has its specs listed in millimeters, which is more precise. The track widths are listed as 1490mm front, 1495 rear. (2.5mm difference per side, as indicated in the original post.) That translates to 58.661 inches front and 58.858 rear. Luckily, since both round up a near equal amount, the posted USA track widths are still accurate enough for this alignment- if they can be trusted. Things like camber plates and even lowering springs will all mess with this measurement to varying extents.
One last thing, where'd you (er, your friend) find that ruler? I bought one that has 1/64th of an inch, but no metric.
Old 12-05-2006, 10:04 AM   #14
Fav Mod: Engineer
You can verify if the strings are parallel (meaning track measurements are good) to each other simply by extending the strings past the front and rear of the car and measuring from string to string, if the front and back measurements are the same your golden.
Abe_Froman is offline   Reply With Quote
Old 12-05-2006, 11:14 PM   #15
Makes complete sense!
I am always worried that I don't have a completely level surface to take the measurements. I wonder how much an unlevel (slightly) surface can affect the alignment?
