Old 09-23-2006, 04:30 PM   #1
HowTo Contributor
Car: 04 Subaru STI
Fav Mod: More power
Exclamation Oil catch can install (cheap & nice)
Sceond post on this site. Good info here.
I thought I'd try to do my part and show pics of an oil catch can install I did tonight. I bought two of these catch cans on EBAY for $29.00 each. I liked them because besides being shiney, they could be dissasembled with allan screws which would allow me to insert a filter inside. They seem very well made as compared to the major brand names that sell for $129 and such.
Billett extrusions, tapped threads, matte finish etc.
Here is the filter I bought. For a Lawnboy. Got it at Lowes for $5. SHould be able to do two cans with it if you cut it better than I did.
It turns out that the yellow teflon tape sold at hardware stores supposedly isn't for natural gas, but was really developed for gasoline. I had some around and did the threads on the top fittings and the drain on the bottom. The sight glass fittings were already done. I JB Wellded a rubber radiator overflow hose into the fitting I was going to use for the inlet. This will take the oilly inlet air to the bottom of the can, and any oily air will have to go upwards, AND through the foam filter to get back into the engine. The silicone you see inside the can was put on by the manufaturer.
I moved a small horn-like item on the passanger fender well (for an alarm?) and tied it up with zip ties. There are a couple of pair of threaded screw holes already in the strut tower. I widened the holes in the bracket that comes with the can and used some metric bolts and washers to attach it.
Simply screw the can on and it's time to plumb the hoses.
I used two Tees to connect the 3 sources of oilly air together. One from the drivers side cylinder head, one from the passanger side cylinder head, and the one from the crankcase. I bought the 1/2" heater/vacuum hose at the autoparts store.
Looks pretty neat I think. Hopefully it works well. I may later make a bracket so I can use both of the cans. I'll plumb the crackcase breathers into one, and the cylinder head breathers into the other. I'll make that decision based on how fast this one can fills up.
DuckStu is online now   Reply With Quote
Old 09-23-2006, 04:49 PM   #2
Car: 04 SRT-4
nice writeup do you have the link to where you can buy this can ?
thanks
kookoo102 is offline   Reply With Quote
Old 09-23-2006, 05:28 PM   #3
HowTo Contributor
Car: 04 Subaru STI
Fav Mod: More power
Sure. There are a few on ebay for $45. But I found some for $29.
Here is a link to one.
http://cgi.ebay.com/ebaymotors/OIL-R...31066603QQrdZ1
Old 09-23-2006, 06:01 PM   #4
Fav Mod: Ricer Flyby
looks good
WESTI is online now   Reply With Quote
Old 09-23-2006, 07:22 PM   #5
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Trader Rating: (12)
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
nice writeup
Ikon is online now   Reply With Quote
Old 09-24-2006, 09:58 AM   #6
Fav Mod: All of them
Very nice! I have been waiting to get a catch can but dont want to spend $120 for a can. I think I might try this.
Partysub is offline   Reply With Quote
Old 09-25-2006, 01:16 PM   #7
One more question. Did you buy the 9mm or the 15mm fitting size?
Old 09-25-2006, 06:00 PM   #8
HowTo Contributor
Car: 04 Subaru STI
Fav Mod: More power
The seller (purchase4lessnow) never asked that. Not sure if they really have 2 sizes.
The barrel part of mine measures 14.5mm, and 1/2" ID fuel/vacuum hose from the autoparts store fit right over it with moderate pushing. It fit even easier over the 1/2" hose barbs in the stock system or the extra one I got with the Perrin turbo inlet hose. Nothing required clamps, although I did use up a few of the ones I had about.
Old 09-25-2006, 06:47 PM   #9
Thanks for the info.
Old 09-25-2006, 06:57 PM   #10
Car: 04 WRB STi
Fav Mod: ACPT CF DS + Cobb Stg 2
Send a message via Yahoo to stituner420
How is this working so far?
stituner420 is offline   Reply With Quote
Old 10-24-2006, 01:25 PM   #11
It says you did 2 of these, where did you mount the other?
DILLIGAFRacing is offline   Reply With Quote
Old 10-25-2006, 11:30 AM   #12
HowTo Contributor
Car: 04 Subaru STI
Fav Mod: More power
I didn't install the second one. I thought I was going to use 2,...one for the valve covers and one for the crankcase breather,...but I only had room to easilly mount one, and being as they both just go back into the turbo inlet hose, I figured there was no point unless there was lots of blow-by.
I have yet to detect and evidence of oil on the sight glass, so I wont be ionstalling to second one.
Old 03-14-2007, 12:43 PM   #13
Car: 06 sti
what r the benifits of this product? how is it working so far? ebay better than name brands or th same?
bhp808 is offline   Reply With Quote
Old 03-16-2007, 08:21 AM   #14
Car: 06 sti
bump for last question....
Old 03-25-2007, 06:09 PM   #15
Fav Mod: Front Mounts
That was a great write up!!! The pictures are great too... i just bought a catch can off a friend and we were looking at where the lines were and got real confused. Again nice write up, thanks
JayTee is offline   Reply With Quote
