Old 12-25-2007, 07:18 PM   #31
Titanium Member
Fav Mod: Modified Stock Heat Shield
Default Re: HSPN TV: How-To / Install - Perrin Lightweight Crank Pulley
Originally Posted by Chris05STi View Post
Tip on tension of the belts: You should be able to twist the belt only 90 degrees when it should stop twisting, that is the tension you want.
Very cool tip. Thanks.
Old 02-23-2008, 07:06 AM   #32
Car: wrb 2005 STi
Fav Mod: FP GREEN
Send a message via AIM to blueman05
now theres 2 belts there and this may sound like a dumb question but is one of those the timing belt? im trying to find out if im able to do the timing belt myself or if im better off having a shop do it? also will install the perrin pulley screw up the car if it has a protune?
kevin
blueman05 is offline   Reply With Quote
Old 02-23-2008, 07:10 AM   #33
Car: wrb 2005 STi
Fav Mod: FP GREEN
nevermind i know none are the timing belts... is one the ac belt and the other acc belt? ill prob replace those on my own but the timing belt im prob better off having a shop do it.... was thinking about doing that crank pully but didnt wanna screw up my tune
kevin
Old 05-11-2008, 08:39 AM   #34
Car: WRC Blue 2005 STi
As a heads up, I found out the hard way about the Woodruff key Subaru uses on the crank. It's the little piece of metal you fit into the key way on the crank pulley, make sure it doesn't move around when taking one off. Mine wasn't flush and level and now I have to go to the dealership to get it fixed so I can get my STi running again.
davidmount is offline   Reply With Quote
