Old 03-15-2007, 11:56 PM   #31
Car: 06 AW STI
Fav Mod: Hardwired 8500
how much does an install cost? im def. doing this myself if its any sig. amount of money.
NorCALSpeed is offline   Reply With Quote
Old 03-16-2007, 10:51 AM   #32
Fav Mod: All of them
Most shops will charge you about an hour in labor. Its really not that hard to do if you follow the write ups. I did mine in an hour in a freezing garage in VT.
Partysub is offline   Reply With Quote
Old 03-16-2007, 10:26 PM   #33
Car: 06 AW STI
yeah i found a great DIY post on it. ill be doing it myself, hopefully i dont blow myself up.
Old 03-22-2007, 08:22 AM   #34
Car: 04 STI
Fav Mod: Koni shocks
So you must use a short peice of hose to connect the fuel pump to the fuel filter? Re-use the stock sock and your done? Does the wiring plug right in or do you have to splice in which you would then need some water proof connections? Thanks guys, nice pictures!
kinger is offline   Reply With Quote
Old 03-22-2007, 08:27 AM   #35
Car: 06 STi/00 L
Fav Mod: trunk monkey
Originally Posted by kinger
So you must use a short peice of hose to connect the fuel pump to the fuel filter? Re-use the stock sock and your done? Does the wiring plug right in?
YES
YES
YES
kessler89 is offline   Reply With Quote
Old 03-22-2007, 08:38 AM   #36
Car: 04 STI
Awesome shot and sweet, I like that! Thank you!
Old 03-28-2007, 10:54 AM   #37
Question What went wrong??
Great thread -appreciated the pictures - I wish I had found this before I installed mine as it would have made things go a lot faster. I have a problem which I am hoping someone can shed some light on. I have a '04 STI. Presently just have a 3'' muffler system I built myself (all stainless) from the mid pipe back. I have a COBB unit unmarried at present and a 3'' mid pipe ready to install once I resolve this problem. After installing the pump (standard 255LPH, not the high pressure version) it now has a stumble (at approximately 4500 - 5000 RPM) during hard acceleration through the gears. I used the original wire harness versus the one provided (it fits the pump and since it was factory I left it) and I used the Walbro provided sock filter. I agree it looks inadequate compared to the factory but I did not have a new factory when I did the installation. I have pulled the pump thinking I have a defective unit but since it will not be re-installed until this weekend I am looking for additional things to check. Anyone ever hear of this problem?? Or have any suggestions. I also notice a comment regarding the sock being the only filter (the canister above the pump in your picture holds a filter but until I called the Subaru part guy on it he kept claiming the sock was the one and only) not so. Note - I experience the interference fit (two tips touching) that were identified in the thread. I was concerned with the two tips rubbing (wear and maybe metal into system) so I cut the hose slightly larger than the distance between the two pumps and remove the screw holding the filter bracket. This allows the two units to be attached to the hose and you can seat the pump in the vibration isolator at the bottom. The middle portion is at a V but can be pressed in (compressing the isolator) and the upper filter can be re-attached
Any comments will be appreciated
bbgiii is offline   Reply With Quote
Old 03-28-2007, 10:57 AM   #38
Question What went wrong?????
Any comments / ideas will be appreciated
Old 06-08-2007, 12:53 AM   #39
Car: 04 Subaru WRX STI
Send a message via AIM to 1STI2NV
Default Re: Walbro Fuel Pump
ok good write up
got a question
is there any way to know if there is one of those installed in the car alrdy
why i ask because i just bought a 04 sti modded alittle
or do i have to pull the dam thing out of the car? and look
1STI2NV is offline   Reply With Quote
Old 06-08-2007, 11:17 AM   #40
Originally Posted by 1STI2NV
ok good write up
got a question
You would have to take it out of the tank and look at it.
Old 06-08-2007, 12:03 PM   #41
ok good write up
got a question
You should just ask the person you bought it from since it was so recent.
volkl23 is offline   Reply With Quote
Old 06-30-2007, 01:13 PM   #42
Car: 04 WRX STi
Fav Mod: Whiteline Everything
Send a message via Yahoo to scotty20bsp
I just replaced the fuel pump today, Easy. Don't get the kit, just the pump! Also, did the new top mount Aps intercooler. Time for a Pro-tune.
scotty20bsp is offline   Reply With Quote
Old 07-02-2007, 07:13 PM   #43
so is everyone just re-using the stock filter thing that the walbro kit includes?
This may be a stupid question but is a protune needed after installing a Walbro 255? If so, I am getting tuned in 2 weeks, what should I do? Install the day before?
TVC15 is offline   Reply With Quote
Old 08-05-2007, 03:41 PM   #44
Car: 2005 Subaru WRX STi
Fav Mod: APS TBE
Call the tuner of your choice and ask them what they think. No tune is necessary per threads here and on NASIOC.
weakness is offline   Reply With Quote
Old 08-09-2007, 09:33 PM   #45
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
Trader Rating: (21)
Send a message via AIM to AndrewSS
thanks for the write up, I followed it during my install tonight
AndrewSS is offline   Reply With Quote
