Old 07-29-2006, 04:22 PM   #1
Car: 05 STi Silver
Fav Mod: Rumble + Torque = COBB Stg2
Exclamation How To do the Pillarless Grill Mod
First remove the grill, it’s easy there are 4 clips along the top edge and two clips down below near the corners. Push the tabs down and push the grill out, you’ll need a screwdriver to push down the lower tabs, be careful because they are not very sturdy.
You can see the tabs in this picture
On the back of the grill, pop out the four metal tabs that hold down the mesh (shown in this fuzzy pic) and remove the mesh.
Hack off the pillar using a dremel, or if you don’t have one, use a utility knife and drill like I did.
Holy CRAP, it looks like I’ll need to throw it out!?
Never fear, file, grind, file, grind, file, grind, keep going until it’s smooth, this part takes a while. I used the dremel cutting ring in my drill, an actual dremel would work better than a drill.
Then use sandpaper, starting with 80 or 100 grit working your way up to 220 then 400 or 600 grit to polish it. This part takes a while too.
Now clean it and let dry. I just used formula 409 to clean it off. Make sure you don't leave any residue or the paint won't stick.
Paint with 3 coats of Rustoleum textured black for plastics. (I used plain black, it’s glossier, and shows any imperfections in the modification, textured black will be more forgiving).
Replace the mesh and its four metal holding clips. The STi badge is held on with two nuts, not pictured because it will be obvious once you see the back of the mesh.
Ready to go!
To put back on the car, pop in the 6 clips and you’re done. Enjoy the cleaner look.
TRM 03-AUG-2006: added to the How-To catalog sticky
Kirv is offline   Reply With Quote
Old 07-30-2006, 05:25 AM   #2
Car: 2005 Subaru STi
Fav Mod: Cobb Swaybars and Kartboy Endlinks
What does it look like on the car? Got a pick?
krees23 is offline   Reply With Quote
Old 07-30-2006, 07:51 AM   #3
Hey nice write-up. When I get my STi, this is going to be my first DIY mod. I think this mod looks so clean. By the way, how hard is it to take off the STi logo on the grill? I like the logo on there, but I just want to know just in case I feel like taking it off.
IWantAnSTi is offline   Reply With Quote
Old 07-30-2006, 10:06 AM   #4
Car: 2004 STi, black
Fav Mod: 18" HRE's
Very cool mate, how does the underside of the grill look?
dustybottoms is offline   Reply With Quote
Old 07-30-2006, 11:50 AM   #5
Fav Mod: a garage
I've done this mod myself. You may want to add steps where you bondo over the bumps on the bottom. However, it will be hard to get it to look great. It will look good, all i'm saying is that body filling is a skill that takes time to get right.
The sti logo is very easy to get off. In fact you might want to be careful not to pop it off during this process.
If you have the $$ then a pro job by this guy is worth it: ese-grill (pillar-less) installed
mine: Did the pilarless mod myself
Old 07-31-2006, 07:56 AM   #6
^I saw your thread a while ago and you are the one that made me fall in love with this mod. Yours looks great, especially on your black car. I hope that my STi will be black so it will look that clean.^
Old 07-31-2006, 09:26 AM   #7
Muller Chevrolet
Fav Mod: a new 08 STi
ok so what exactly is used for filling? it's just called bondo? lol
the guy that i'm going to have do it (professional painter, auto restoration man) wanted to know what to use to fill it since i told him others have done it.
Old 08-01-2006, 08:21 AM   #8
Car: EVO IX
Can someone recommend a good bondo to fill this out and where to get it? Sorry im a bondo noob. Thanks!
rydeordie is offline   Reply With Quote
Old 08-01-2006, 05:08 PM   #9
Car: 05 STi Silver
i agree, i didn't use bondo, and if you get up close to mine, you can tell that the pillar was hacked off. Bondo FTW!
Old 08-02-2006, 07:04 AM   #10
Car: 2008 A4 6MT LOADED
Fav Mod: I miss my Subaru...
lol i got lazy and didnt bondo it either.. bought the stuff but didnt touch it.. after cutting everything it doesnt look too bad except at the very back where it tilts in.. but you cant see unless you get super close..
another thing.. u hiring a guy to do it or is he like your friend thats helpin out? because its super easy and you can do it by yourself.. just make sure u primer it a few coats and fine sand the primer.. as well as clear coating and wet sanding that.. otherwise it will have sanding marks
and the stuffs just called bondo.. its like the brand.. bondo body filler.
FujiApples is offline   Reply With Quote
Old 08-02-2006, 07:57 AM   #11
Muller Chevrolet
the guy is a friend and works at our dealers on certain days for customers or our trade in's...he's done some stuff to my old celica and a few things for my sti.
Old 08-02-2006, 11:08 AM   #12
Fav Mod: BOV and MBC
glazing putty is better than bondo IMO. it comes in a smaller container and you dont have to mix it with hardener. heres a pic of my grille.
Old 08-02-2006, 05:39 PM   #13
Muller Chevrolet
where can i find this ****?
Old 08-08-2006, 06:02 PM   #14
Car: 05 PSM STi
what paint did you use to paint your grill?
05soobieSTi is offline   Reply With Quote
Old 08-08-2006, 08:32 PM   #15
Car: MR-S
Fav Mod: nike shoes
Send a message via MSN to tecnica
I used glazing putty as well. I picked mine up from napa. It costs about 7 bucks and will last a life time.
tecnica is offline   Reply With Quote
