Old 07-18-2006, 10:24 AM   #1
Car: 06 STi
Exclamation How to Paint Your Wheels (the right way)
OK… so you want to paint your wheels a different color. Well, there is definitely a right way and a wrong way to do this. Your best bet (IMO the “right way”) is to use a quality automotive paint and a spray gun. This way you can control layer thickness and the level of gloss extremely well. Below is a step by step process:
1) Get the vehicle up on jack stands. Make sure you use quality jack stands that are rated for the weight of the vehicle (I left a jack by each jack stand as a secondary protection).
2) Remove the tires from the wheels (NOTE: You can tape off the tire and spray the wheel with the tire mounted... but you WILL eventually get premature chipping/cracking around the tire).
3) Clean the wheels extremely well (you will need a large bucked with soap and water, and Simple Green):
a) Wash the wheel with soap and water
b) Set it out on a towel and spray the wheel (front and back) with Simple Green
c) Move on to the next wheel
I did went through this process twice (meaning each wheel was washed with soap and water twice and each wheel was sprayed with Simple green twice)
When you are finished, wash each wheel to remove any residual Simple Green.
This is how they should look at this point:
4) Scuff up the wheel. The paint will only adhere properly to surfaces that have been scuffed (I prefer to use automotive scuff pads. I find most sandpapers to be too rough for aluminum wheels).
You are now done with the prep work and are ready to start painting. You will need (do not be intimidated, any automotive paint store will supply you with some or all of these products with ease):
a) A respirator (you can get 3M modle 51P71 (07191) at any automotive paint store for ~ $25… its good for 40 hours)
b) A compressor that can work in the 40 PSI range.
c) A spray gun (if you only plan on doing this once, you can buy a $15 gun at harbor freight that will work wonderfully)
d) An adhesion promoter (I used Bullydog adhesion promoter (ETPO-123))
e) 1 Pint of Paint in your desired color – if you want this to last years, you need to buy a quality automotive paint. I used Nason Ful-Thane 2K Dupont Urethane in 1950 Chrysler Black… But any automotive paint store will be able to supply you with a quality paint.
f) Urethane reducer – unlike spray paints, automotive paints need to be reduced.
g) A hardening Catalyst – I used Nason Ful-Thane 483-15 Catalyst. Again, any automotive paint store will be able to supply you with a hardening catalyst.
6) OK… now you are ready to start painting. Lay the wheels out FACE DOWN on whatever surface you will paint on (I used a painting tarp in my garage). Fire up the compressor and let it come up to the appropriate pressure (e.g. 150 PSI in my case). NOTE: If you want you can wipe the surface of the wheels with a paint prep or alcohol… it really is not necessary with the level of prep we have gone through, though.
NOTE: now is the time to tape off anything you do not want to get a fine mist of paint on. If you are spraying in your garage and your vehicle is up on jack stands in said garage, you want to completely mask the vehicle. I ran painting tarps over the entire vehicle, taped the seams together, and taped the ends to the floor.
7) PUT ON YOUR RESPIRATOR (Paint is extremely toxic and will damage your lungs/internal organs if spray without a respirator. Spend the $25 on the respirator!!)
8) Mix the paint, urethane reducer and hardening catalyst using a 8/2/1 ratio (meaning 8 parts paint, 2 parts urethane reducer, and 1 part hardening catalyst) and pour it into your spray gun.
9) Spray the wheels with 1 or 2 quick coats of the adhesion promoter and let sit for ~1 minute.
10) Hook the spray gun up to the compressor and test the spray output against something other than the wheel (cardboard, for example). Once you are comfortable with the gun, begin spraying the wheels. I put 5 extremely light coats on each side.
Here is how my wheels looked at this point:
Oh yea… and here is why we masked the entire car in the jack stands… see all of that black paint residue on the plastic? Now imagine that being on your vehicles finish.
Here is a look at the finished product:
06grip is offline   Reply With Quote
Old 07-18-2006, 10:38 AM   #2
Car: WRB GDF-E
Fav Mod: Majin
Great write up! I did mine the easy way, turned out good enough for the winter rims that they are going to be...
Old 07-18-2006, 10:42 AM   #3
bah spray paint is the ghetto way to say how you colored your rims..
STiSchucky is offline   Reply With Quote
Old 07-18-2006, 10:45 AM   #4
Car: 96 Outback Wagon
Fav Mod: Autobot Decal
Trader Rating: (21)
Send a message via AIM to Einobaka
Nice write up!
Einobaka is offline   Reply With Quote
Old 07-18-2006, 10:46 AM   #5
Car: 06 CGM STi
Fav Mod: kicks
Send a message via AIM to wrx23x
nice write up! i just painted my rims yesterday the same way you did
wrx23x is offline   Reply With Quote
Old 07-18-2006, 10:49 AM   #6
Car: 06 STi
Thanks.
wrx23x - what color?
Old 07-18-2006, 10:55 AM   #7
Car: WRB GDF-E
Fav Mod: Majin
so? I wanted a cheap/easy/quick fix for some damaged rims...
Old 07-18-2006, 11:06 AM   #8
Car: 06 STi
Just as you have that mentality, there is nothing wrong with spray paint. It will not hold up over years of use, but is a cheap/easy/quick fix for damaged winter wheels. I wanted something that would look great and hold up for years.
Old 07-18-2006, 11:13 AM   #9
Car: WRB GDF-E
Fav Mod: Majin
I see your point... to elaborate on my point, I did not have an easy way to dismount and remount the tires (which are only going to last till october anyways), I only had a limited amount of time to complete the work, and we actually used a scuffing and cleaning compound for the prep. If they last through this season I will be happy, because next year I will be running my new gram light 57fs and will be able to spend the time to do it right. It looks fine for now...
Old 07-18-2006, 11:29 AM   #10
Car: 06 STi
Cool... I've been looking at the gram light 57fs... nice choice.
Old 07-18-2006, 12:14 PM   #11
Del
IWSTI Club Level 1
Car: 2003 WRB WRX
Fav Mod: Multiquote
Awesome man! Bookmarked!!
Del is offline   Reply With Quote
Old 07-18-2006, 12:50 PM   #12
Car: 2005 Silver WRX STi
Looks very good.
speedsnice is offline   Reply With Quote
Old 07-18-2006, 12:55 PM   #13
Fav Mod: **JDM Goodies**
Send a message via AIM to Allen504tke
Stealthy FTW!
Allen504tke is offline   Reply With Quote
Old 07-18-2006, 12:58 PM   #14
Car: 07 STI OBP
Fav Mod: we will see soon...
would it matter if you paint on gold or silver, or is it all the same end result?
JustinH is offline   Reply With Quote
Old 07-18-2006, 01:14 PM   #15
Car: 06 STi
the color makes no difference. Just remember... it's all in the prep work. Follow the instructions above and any color you spray will look phenomenal.
