Old 07-23-2006, 05:32 PM   #46
Car: 06 STi
Originally Posted by DragonXero13
Thanks a lot will do!
Though I really hope that I find some place that will powdercoat my wheels for 40 a peice!
remember, you get what you pay for. You may find a shop that will powdercoat your wheels for 40 (which is a deal I would be weary of, BTW), but they will surely use a high temp bake and cure process. Further, powdercoating WILL weaken an aluminum wheel (even if you use a low temp process... although to a lesser degree). As I stated earlier, if you are into drag racing and/or autox, this becomes a significant safety concern.
06grip is offline   Reply With Quote
Old 07-23-2006, 06:33 PM   #47
Car: 06 STI
How would it weaken the wheel?
DragonXero13 is offline   Reply With Quote
Old 07-23-2006, 08:58 PM   #48
Car: 06 STi
The powdercoating process relies on heat (typically 400 - 450 degrees F) to heat and cure the alloy. Excessive heat weakens aluminum (to what degree depends on how excessive the heat).
Old 07-23-2006, 09:00 PM   #49
Car: 06 STi
Originally Posted by pc06sti
How long did you wait between each of the 5 coats that you applied?
With the spray gun, I would spray one wheel at a time... by the time I finished a coat on the 4th wheel, I'd start with the next coat on the first wheel. This essentially allowed for ~5 minutes between coats.
Old 07-24-2006, 01:34 PM   #50
Car: 06 STI
How long did it take to paint the wheels? Powdercoating will take two weeks and I can't take that with my Daily Driver. I don't drive the car every day but .. How long would this whole process take?
Old 07-24-2006, 02:39 PM   #51
Car: 06 STi
Two days.
Day one: run to discount tire and get the tires dismounted, get the wheels home, prep, scuff, spray, let them dry (12 hours in a dry climate, 24 hours in a humid climate).
Day two: get up and get the tires remounted.
Done. Paint them... you will not regret it.
Old 07-24-2006, 03:17 PM   #52
Car: 06 STI
This is going to be hard .. I do'nt have an extra car and no one would be able to take me anywhere .. -.-
Old 07-24-2006, 05:37 PM   #53
Car: 06 STi
Hit up one of your buddies for a ride (actually two rides). It is not as hard as you may think. Hell, if I were in Washington, I'd help you myself.
Old 07-24-2006, 08:38 PM   #54
Fav Mod: HKS CARBON TI
i dodnt think i'm brave enough to do something that extensive to my wheels
Old 07-24-2006, 11:11 PM   #55
Car: 07 STI OBP
Fav Mod: we will see soon...
+1 i sure as h3ll would not do that since im an idiot, paying 300-400 to get it done is not bad to ensure a good result.
JustinH is offline   Reply With Quote
Old 10-19-2006, 05:57 PM   #56
Car: 06 WRX
Send a message via AIM to lilmilan00
Hey nice work man i just went out today and spent 133.37 on all that stuff, and im looking to paint the rims tihs weekend. oh yeh im painting them gold..lol
lilmilan00 is offline   Reply With Quote
Old 10-21-2006, 01:47 PM   #57
Car: 06 STi
Good luck (you'll be fine)... feel free to PM me if you have any questions.
Old 10-21-2006, 10:29 PM   #58
Car: White 06 STi
Fav Mod: Forged Bypass
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
looks great, good writeup but more pics next time!
ilami01 is offline   Reply With Quote
Old 11-10-2006, 02:04 AM   #59
Car: 05 STi CGM
Fav Mod: JDM Foglights
I am all prepped and ready for paint. There were a couple small/tight spots that I accidentally went down to the bare aluminum- everything else is good, down to factory primer. Should I prime the entire wheel or not worry about these small areas of bare AL and just paint over them? Thanks, nice write up.
SCOOBYTRAP is offline   Reply With Quote
Old 11-10-2006, 04:53 PM   #60
Car: 06 OBP STI
Fav Mod: dedicated snows
Default Powder Coat Weakens
The factory wheels are forged. The forging process aligns the metal grain so that they run in the same direction (also called hard working the metal). This gives the metal more strength. This is why forging is stronger than casting an equivalent part (no alignment of grain). When you heat the wheel int he powder coating process it allow the aligned grains to migrate (no longer aligned). This will definetly weaken the wheel (or any forged metal that is over heated)
Finally got to use my ME degree...........
Atomic is offline   Reply With Quote
