Old 07-13-2006, 06:32 AM   #1
Poor Speed Racer
Car: 96 328
Fav Mod: Race Car!
Exclamation How To Swap Trunks
  1. Remove lock from trunk
    Remove the glow in the dark release handle. Once this is done you can get to the lock. Simply twist the orange thing around, and pop the metal rod. Take a screw driver (you also might need a hammer as well) and pry that black clip off. Its really tight on there so you will need to use some force (this clip is exactly like the clip securing the brake lines).
  2. Remove latch from trunk (optional as it may not be needed)
    Remove the 2 bolts, twist yellow thing around and pop out that metal rod. You will also need to pop out the cable from that glow in the dark handle.
  3. Remove trunk
    Remove the 4 12mm bolts that secure the trunk to the trunk arms. Beware that the STi trunk weighs a TON (something like 50+ lbs). You will also have to unplug the 3rd brake light and clip all the wire retainers off the sti trunk arm to get the trunk off.
  4. Remove Tortion bars
    This is the PITA step here. Now, there are 2 ends to the tortoin bar. One end that attaches to the trunk arm and the other that is locked in place. First, get a big wrench or a big screw driver (as long as its big, you will need the torque). The part that attaches to the Arm looks like a U, place that wrench in the under side of that U and pry it off the moving piece on the trunk arm. Move that piece up so it fits flush against the arm, and let that U rest agaist there. Now, you are 1/3 done. Take that same wrench and pry out the ends of the U, once this is done, it might spring a little since its torqued a good bit. Once you have done this simply pull the bar out and start on the second one!!
  5. Install tortion bars
    Just reverse the removal procedure. Place the static part of the bar in its older, and position the trunk arm side as close as possible. Lift the trunk arm up and using that wrench pry the ends of the U into their olders. Then pty down on the U and extend that moveable piece on the trunk arm so it fits onto the bar. Once you have done this, you are done and good to start ont he other bar.
  6. Install trunk
    Same 4 bolts and remember to check that the trunk fits right before you try to close it.
  7. Install Latch
  8. Install Lock
  9. Remove brake light
    Remove Seats
    Unplug the light which is in the trunk right under the light, loosen the 2 screws that retain the light.
    Take your hand, slide it under the lid and pop off the rear lid that the light sits on (there is a big whole for the light). There are no screws, just 4 (i think its just 4) tabs that hold it in place. You can get to them from inside of the trunk as well.
  10. Install brake light
    Swap the lids (they pop right back in), plug the light back in and secure the 2 screws. ALL our cars have 3rd light locations for the STi, and the other third brake light, so you dont need to do any electrical work.
now all you have to do is look at how hot your new trunk is
Old 07-13-2006, 08:28 AM   #2
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
Nice writeup!
SoaReS is offline   Reply With Quote
Old 07-13-2006, 11:12 AM   #3
Car: 06 STI
Fav Mod: Prodrive oval tip
nice... btw, who's the dude with "got united" shirt?
Old 07-13-2006, 06:38 PM   #4
Car: 06 obp/g sti
Fav Mod: Whiteline sways
Send a message via AIM to bickford
nice job! Im going to need this at some point.
bickford is offline   Reply With Quote
Old 07-13-2006, 06:51 PM   #5
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
Thats a guy?
Old 07-13-2006, 07:09 PM   #6
Car: 08 specB
Send a message via AIM to denver133
THANK YOU!!!! I am swapping trunks this weekend!!!
denver133 is offline   Reply With Quote
Old 07-14-2006, 04:58 AM   #7
Poor Speed Racer
Car: 96 328
Fav Mod: Race Car!
haha, the "got united?" guy was a friend of the guy that i swaped trunks with
I decided since i have never seen a trunk swap how to that i would post one. It sucked calling my friends 10+ times to make sure that i was doing it right.
Old 07-14-2006, 05:22 AM   #8
Bronze SEMA 2007 Sponsor
Originally Posted by ESsTeAEyEe
Thats a guy?
yeah he looks to be in his teens maybe early 20's .... maybe!!!
STi_4_Daddy is offline   Reply With Quote
Old 07-14-2006, 05:34 AM   #9
Car: WRB 2005 STi
Fav Mod: Borla Exhaust
The only thing I would add, is to remove the step for swapping the latch. I've done a swap and it's not needed and will only cause people pain when trying to get it lined back up. Other than that, great write up.
klaymon is offline   Reply With Quote
Old 07-14-2006, 05:34 AM   #10
Poor Speed Racer
Car: 96 328
Fav Mod: Race Car!
yea, they were both young... really young.
at one point he asked me my age.. and was like "oh... wow"
I felt old after that...
Old 07-14-2006, 01:46 PM   #11
Car: 08 specB
^^^Should of kicked him in the nuts
Old 07-19-2006, 05:18 AM   #12
Poor Speed Racer
Car: 96 328
Fav Mod: Race Car!
ROFL!!!!!
yes i should have.. but then he might have fallen on my trunk
Old 11-22-2006, 06:53 PM   #13
this space for rent
Car: 04 psm sti
Fav Mod: custom 03 seats
^^very nice write up i am gonna be changing out my torsion bars on friday and went searching and came across this,great write up
sti-liger is offline   Reply With Quote
Old 11-25-2006, 01:47 PM   #14
Car: OBP 05 STi/silver
Fav Mod: RCE Tarmac II's
Send a message via AIM to soob'n
I finally swapped trunks and tried putting on a wingless. Everything was painless until I tried closing my trunk. It refused to "click" into place. I tried adjusting the latch as to get it lined up but it just wont close! It was advertised as an 04'wingless but maybe it's a "bug-eye" model. I dont think it would matter though. I just cant figure out why it wont click. Any help would be great. THANKS!
soob'n is offline   Reply With Quote
Old 11-25-2006, 02:25 PM   #15
Car: 07 UGM STI
Fav Mod: Cobb
Maybe I'm missing something but, if your swapping the same color can't you un-bolt the 2 12mm on each side and swap the trunks that way? Then swap out the lock cilynders. Or do the torsion bars differ?
RAAZ227 is offline   Reply With Quote
