Old 04-03-2007, 02:53 PM   #31
Question for you guys. I have an '04 STi and the trunk was swapped with an '05 STi trunk. Not sure if the third brake light (led one on the wing) wiring is different on '05 but I don't see anywhere to plug it into in my trunk.
It's very short...only comes about half way down the trunk arm so the wire in my trunk (if there was one) should be fairly long but there's nothing I can find that will reach, let alone plug into it...any ideas?
This is an '04 STi so it would have originally had the third brake light as well...i'm confused...
2000Accord5sp is offline   Reply With Quote
Old 04-04-2007, 06:54 PM   #32
Car: 04 Subaru WRX STI
Fav Mod: TBE
Send a message via AIM to AntDot
Originally Posted by soob'n
I finally swapped trunks and tried putting on a wingless. Everything was painless until I tried closing my trunk. It refused to "click" into place. I tried adjusting the latch as to get it lined up but it just wont close! It was advertised as an 04'wingless but maybe it's a "bug-eye" model. I dont think it would matter though. I just cant figure out why it wont click. Any help would be great. THANKS!
yeah my silver seibon lid did the same thing...im just pushed harder hahah and it clicked...be sure not to click that lil lever from where it is now....i did and had to take my back seats apart to flip it again to open the trunk. yeah i know...dumb...but i was intoxicated a lil bit. good times
AntDot is offline   Reply With Quote
Old 04-13-2007, 05:56 PM   #33
Fav Mod: Fabspeed
any estimate as to how long this takes? im trading my wingless rs trunk from my bugeye with an STi trunk from an 05 tomorrow. youd suggest not changing locks either?
ACHAHockey is offline   Reply With Quote
Old 04-13-2007, 07:30 PM   #34
Fav Mod: Fabspeed
just kind of answered my own question. it took me about 30 minutes to get the back seats, the torsion bars, and the trunk off by myself (wanted to get ahead for tomorrow). Only other question is, for taking the 3rd brake light off, i took the plastic clips off the rear deck that the light sits on, now how do i get that deck off?
Old 04-14-2007, 07:31 PM   #35
Car: 06 OBP STI
Fav Mod: dedicated snows
To get the rear deck off you need to remove the trim on either side of the rear seat back. You need to start at the door floor trim (it pulls right up, maybe one screw at top, or on next piece cannot remember- you will see it down a recessed hole, use a light) and work your way up.several pop rivets, pop cover off seat belt and unbolt, couple philips screws and your done. I assume from above, your seat back is out already - it needs to be out.
Atomic is offline   Reply With Quote
Old 04-16-2007, 09:53 PM   #36
Fav Mod: Driving School / Trunk swap (no attention ftw)
Default Re: How To Swap Trunks
I swapped with ryan (achaHockey) a few days ago...with 2 people, this was an unbelieviably easy job! Even the torsion bars were no big deal. Highly recommend having a second set of hands.
~Jesse
p.s. We swapped locks, but i don't see any reason to take off the whole clip (gold) unit which holds the trunk down. Just swivel the orange piece, pull out the black tab, and slide one out and put the other in. Super easy.
mgsm666 is offline   Reply With Quote
Old 04-17-2007, 09:57 AM   #37
ADDITIONALLY: We took off the trunk lids before we did torsion bars, making the torsion bars no big deal. I would definately recommend doing it this way...
Old 04-18-2007, 04:32 PM   #38
Car: 2006 White Sti- Borl
Fav Mod: Borla "Hush" Exhaust
Send a message via AIM to '06sti_kid
Can a 04 WRX trunk replace a 06 STi trunk? Will it align right? and can an 06 STi trunk be placed on a 04 WRX?
'06sti_kid is offline   Reply With Quote
Old 04-18-2007, 05:43 PM   #39
Fav Mod: Fabspeed
should be able to, i heard 02-06 are compatible
Old 04-29-2007, 04:50 PM   #40
Fav Mod: 255's ftmfw
Send a message via AIM to sticop
Thumbs up Re: How To Swap Trunks
mods, i think this should be a sticky please and thank youse!
sticop is offline   Reply With Quote
Old 04-29-2007, 04:51 PM   #41
if im swapping an 04 sti with an 04 wrx winged will we have to swap latches?
Old 04-29-2007, 05:16 PM   #42
^^^ nevermind im a poopooface and didnt read all the posts carefully
Old 05-04-2007, 03:13 PM   #43
swapped the other day, pretty easy cept the torsion bars are a pita. all that ran through my mind was the pain of getting my finger caught in a mouse trap...x10
Old 08-24-2007, 12:20 PM   #44
Is this guide accurate for an 07 wrx to 07 STi swap as well?
mordak is offline   Reply With Quote
Old 03-12-2008, 09:52 PM   #45
Car: 07 OBP STI
Fav Mod: AutoSpeed Catback
yes it should be, all trunks lids are interchangeable from 03 to 07 models. Do the torsion arms as recommended...
PuccasBad_STI is offline   Reply With Quote
