Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > How-To / Install
Old 09-03-2006, 09:31 PM   #21
Feedback Score: 8 reviews
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
IWSTI Addict since: May 2005
Looks good and much cheaper than the one I made.
I'll post some pics of mine tomorrow. It has a built in gauge, so it brings the cost up a little more..
pt518sti is offline   Reply With Quote
Old 05-09-2007, 08:39 PM   #22
Car: Evolution X GSR
Fav Mod: ARC Ti Shiftknob
IWSTI Addict since: Oct 2004
Send a message via AIM to SNE2040
Default Re: Anyone have some good info on pressure testing?
sorry for bumping an old threat. i really need to vacuum test my car cause 4th gear seems dead to me (3rd pulls a lot harder). when i disconnect the 3 hoses off the inlet (if i have to), with what do i cap them with? any special plug or hose? also which ones are necessary to plug to pressure the car to ~16-18 PSI without anything blowing up? let's say that 1 is the closest to the filter, and 3 is closest to the turbo.
SNE2040 is offline   Reply With Quote
Old 05-24-2007, 02:21 PM   #23
Car: 05 STI
Fav Mod: Utec
IWSTI Addict since: Sep 2004
sorry for the cellphone pic....
but i made mine basically for just the cost of the PVC. I had an extra valve stem that i hook to my tire pressure filler/gauge
higB_0x05 is offline   Reply With Quote
Old 06-19-2007, 10:45 PM   #24
^ what size is that exactly?
Old 11-13-2007, 05:14 PM   #25
IWSTI Addict since: Jan 2007
I might be kind of an idiot for missing it, but I want to be sure of this. Building it is not a problem, but do I just put it on the end of my intake? I have TurboXS FMIC and it would be exceptionally easy if that were the case.
GT4604 is offline   Reply With Quote
Old 02-07-2008, 01:36 PM   #26
Feedback Score: 1 reviews
Car: WRB 04 STi
IWSTI Addict since: Aug 2006
sorry for bumping an old threat but i have some new questions. after presurizing the system and disconecting the air supply (quick disconect) should if there are no leaks shouldnt the system hold at 20 psi or is that air going to come out somwhere. im doing this right now and after i disconect the air gauge slowly drops. i cant realy hear where its comming from though. i am in a loud shop. any info will help. MY CAR IS RUNNING LIKE DOOODOOOO
04superzillaSTi is offline   Reply With Quote
Old 03-18-2008, 08:59 PM   #27
Feedback Score: 6 reviews
Fav Mod: DOM3 DomTuned!
IWSTI Addict since: Dec 2007
Send a message via AIM to johnsm Send a message via MSN to johnsm
I have a APS 525 and i unplug the turbo coupler and put in a home made tester, and pressure the system with 25 psi and the compression drops very slowly and i hear noise coming from manifold area cant figure out from where exactly "its on 07 sti"
Can any one help?
johnsm is offline   Reply With Quote
Old 04-22-2008, 07:30 PM   #28
Feedback Score: 2 reviews
what size is the coupler?? 2 in. for me was the same size as the inlet. 1 and a half was kinda small. i could not find 1 3/4 so i just wrapped the 1 1/2 with tape and hopefully it will be big enough.
starxidiam is offline   Reply With Quote
Old 11-25-2008, 11:30 PM   #29
Car: WRB 2005 STi
Fav Mod: Getting an STi
IWSTI Addict since: May 2008
Send a message via AIM to Thejoyofdriving
Default Re: Pressure Testing
Isnt it bad to pressurize some parts of the system that "dont normally see pressure"?
Thejoyofdriving is offline   Reply With Quote
Old 12-15-2008, 04:18 AM   #30
Car: Your STi ;)
My StuffSubaru Parts
Fav Mod: Everything
IWSTI Addict since: Mar 2005
I usually only put 5 psi or so on the inlet, but I'll put 25 psi on the outlet of the turbo. I've put at least 5 psi on the inlet of at least 300 cars and haven't had an issue yet...
Siegel
Privacy Policy
