Old 10-02-2006, 01:37 PM   #46
Ben
Retired Admin
Car: 2006 Audi S4
Fav Mod: Weight Loss
Send a message via AIM to Ben
Originally Posted by chubs22
Ben,
Thanks for the great vid. I just changed my pads today and I would have never attempted it w/o you posting up this vid. You rock.
Glad to have helped!
Ben is offline   Reply With Quote
Old 10-02-2006, 04:42 PM   #47
Car: 05 STi CGM
Fav Mod: JDM Foglights
Originally Posted by Stee
I'd say follow the FrontRight/RearLeft/FrontLeft/RearRight method for the installation of the lines and bleeding at the same time.
More info here:DIY: How to bleed STI Brembo brakes
Thanks, All I need is a 10mm Flare wrench and I think I should be able to do this tomorrow
SCOOBYTRAP is offline   Reply With Quote
Old 10-12-2006, 04:23 PM   #48
Titanium Member
Fav Mod: Bill
I'm doing it tomorrow, however, I think I'll have all four corners up on jack stands instead of jacking up one wheel at a time.... I gotta rotate the wheels too.....
KarlSTI is online now   Reply With Quote
Old 10-13-2006, 09:53 PM   #49
Car: 07 S204 WannaBE
Originally Posted by Foo_Blyat
what if ur trying to get new fluid like ATE blue in, how do u bleed the old fluid out completely?
Originally Posted by fullerton
^+1
and how much fluid do I need? where I do dispose of the old stuff?
Ben?!?
Foo_Blyat is offline   Reply With Quote
Old 10-13-2006, 11:33 PM   #50
Ben
Retired Admin
Car: 2006 Audi S4
It's hard to fully bleed old fluid, but you can do it eventually. If you cycle 2 or 3 bottles of fluid through the system (keep putting fluid in and bleeding it out) you should get 95% of the old fluid out of the system.
You can dispose of it at any auto parts store like pep boys.
Old 10-28-2006, 12:44 PM   #51
Car: Silver 05 WRX STi
Send a message via Yahoo to import111
I just installed Ferodo DS2500's at all 4 corners today. The video helped me out a lot. I used the stock shims and some anti squeal grease to hopefully keep squeal away. My fluid over flowed like crazy when I got to the 3rd corner (FL). Next time I will know to suck some fluid out with a syringe or something to make sure that does not happen again.
import111 is offline   Reply With Quote
Old 10-28-2006, 02:21 PM   #52
I just use a Motive Power Bleeder. Works like a charm. Alternate between Ate Typ200 and Super Blue, you know you've done a complete fluid flush once the color has completely changed.
Interestingly enough, I bled the brakes when the car had 2200 miles and you wouldn't believe the air bubbles and debris that came out of the calipers! Much, much improved pedal feel now...
docwyte is offline   Reply With Quote
Old 10-29-2006, 05:44 AM   #53
Titanium Member
Fav Mod: Bill
I followed the video and it worked pretty well for me. I used a small flat blade screw driver to take the rubber caps off the bleed valve though because I would easily tear them with needle nose pliars. The SS lines and the HP+ pads work great....noise is not bad at all and the dust seems less than stock pads. Used them for 2 days of autox last weekend and I'm happy with the brake feel.
Old 10-31-2006, 07:32 PM   #54
Fav Mod: Starving my STI
Trader Rating: (12)
Ok so is the only purpose of the shims to prevent brake squeal? If one can tolerate the noise (I honestly don't hear anything), is there a performance gain to be had to go without the shims? The shims don't cover the entire piston surface area... so part of the piston is pressing on the shim and part is pressing on the pad backing plate... if it even squeezes the shim enough to reach it... this can't be optimal can it???
AnorexicSTI is online now   Reply With Quote
Old 02-13-2007, 03:46 PM   #55
Car: 06 Subaru WRX STi
what would one use to clean dirty / squeaky pads and rotors?
is there something I can buy somewhere, or does just using water and a rag do the trick?
pearwear is offline   Reply With Quote
Old 02-13-2007, 04:10 PM   #56
Ben
Retired Admin
Car: 2006 Audi S4
Squeaking isn't caused by dirty pads or rotors, so cleaning them isn't reallly going to solve your problem .
Old 02-14-2007, 01:27 PM   #57
Fav Mod: FYI, I'm a dude
brake kleen or something similar if you want to clean up brake parts. won't fix the squeaky though as ben said. you could try brake quiet on the pads.
Old 04-10-2007, 10:19 PM   #58
Some things I wanted to comment on after doing a SS line install:
1) you guys must have loosened and then re-tightented the brake lines before filming, because I rounded all 4 nuts with my flare wrench. I ended up using a vice grip and that seemed to work better. My nuts are now cylinders.
2) the rear banjo bolt was puzzling to me at first, but then I got a flashlight out and figured it out. Would have been nice to be included in the vid.
3) you can plug the open line with your finger and then take your time getting the new SS line in place - fluid won't run out until you take your finger off.
Minnesota01R6 is offline   Reply With Quote
Old 04-10-2007, 10:28 PM   #59
Car: 06 STi CGM
Send a message via AIM to stevos758
yes. My flare wrench also rounded off the nuts. I highly reccomend just using a vise grips.
stevos758 is offline   Reply With Quote
Old 04-11-2007, 06:55 PM   #60
Ben
Retired Admin
Car: 2006 Audi S4
We pretty much always losened and re-tightened bolts in the install so we didn't look like idiots on camera, but I can tell you that I loosened the bolts with a flare wrench (not a vise grip) and it loosened just fine without stripping. Perhaps you had the wrong size?
