Old 05-22-2006, 05:46 PM   #1
Car: 06 STI
Exclamation How to - Plug and Play with the AccessPORT
Here's some easy How to steps for installing/ Plug and Play the AccessPORT, if you're having any troubles.
Tools:
AccessPORT
First, take your car where it is safe to leave the doors unlocked, such as your garage.
Move your seat all the way back so you have enough room to bend a bit.
Step 1:
Put your key in the ignition and leave it in the "Off" position. Don't turn it, just plug and leave it there.
Step 2:
Under your dash are two green Test Mode Connector. Plug the two Test Mode Connectors together.
Step 3:
Turn your ignition key to the "On" position but do not fully start the engine.
Check to see if your "Check Engine" light is blinking on your dash. You may also hear your radiator fans cycling on and off periodicly. Don't worry it's all in the process.
Step 4:
Plug in the DiagPORT cable that came with your AccessPORT. It's black with red at the tip. Insert the DiagPORT, with the logo AcessPORT facing you, in the diagnosis port connector. The diagnosis port connector is right under your steering wheel and dash.
Step 5:
Now your AccessPORT should turn on and it should state:
AcessPORT- 2.5STi
COBB TUNING
( Year )
Initializing V1.0
Select what you want to do with your AccessPORT. If you want select a base map, select #1.
It will state, " Please choose a new map to flash to ECU
Press OK/Cancel." Press the big button, "Ok". Than there will be a list of maps that you can choose to flash your ECU with.
Your AccessPORT will tell you to, " Turn the car fully off and back on. Then press OK." Turn your ignition key fully off as the picture above and fully on as above as well. The AcessPORT will display a screen that says. " Initializing ECU ......" Once it has completed it's initialization process, there will be a % sign. Wait till it reaches 100% and than the AcessPORT will say, " Reflash Complete. You must turn the car off before starting.- Press OK." Do as followed and than you've just flashed your car using the AcessPORT!
*IMPORTANT* Step 8:
Before driving, disconnect the green Test Mode Connectors!
Drive and feel your new obtained power! Let the ECU learn for a few minutes and than floor as wished.
TRM 03-AUG-2006: added to the How-To catalog sticky
DragonXero13 is offline   Reply With Quote
Old 05-22-2006, 07:31 PM   #2
Car: 06 STI
Fav Mod: Prodrive oval tip
awesome!!!!
Old 05-22-2006, 07:34 PM   #3
520
pwns n00bs
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
wow, very nice! makes something so simple, even simpler!
Old 05-22-2006, 07:36 PM   #4
STI Guru
Fav Mod: Whooshing sounds
Awesome writeup and pictures!
Quick question: Do I need to update the AP itself from the Cobb website to make sure I have the latest software?
Old 05-22-2006, 07:44 PM   #5
Friendlys Suby
Fav Mod: M&J Modified
nice writeup
Old 05-22-2006, 08:19 PM   #6
Car: 06 STI
IIRC, Yes, when they have new map versions than you must update it through the Cobb website found at http://cobbtuning.com/sti/accessport/index.html.
Old 05-22-2006, 08:26 PM   #7
Nanned ®
Good job!
Old 05-23-2006, 10:09 PM   #8
I accept bribes...
Makes me want one more and more!
Old 05-24-2006, 03:04 AM   #9
Car: 05 STI
great write-up!!! I just wanted to add that you only have to connect the green connectors if you are loading a new "base map". You dont need to use those if you are switching real-time maps or clearing CEL codes....
Old 06-03-2006, 09:02 PM   #10
Car: White 06 STi
Fav Mod: Forged Bypass
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
do we unplug those two green connectors that we pluged into eachother?
ilami01 is offline   Reply With Quote
Old 06-04-2006, 12:51 AM   #11
Car: 08 QSM Legacy Spec B
Just wanted to add, that for some people, if your car isn't entering test mode with the two connectors connected under the dash, then you should look to see if a second set of connectors on the passenger side are disconnected(behind the kick panel...would be to the right of your feet near the floor). In some cars these are disconnected and have to be connected in order to get the connectors under the dash to work (this happened to me). Once these are connected, just leave them that way, and only connect/disconnect the ones under the dash.
tjsdds is offline   Reply With Quote
Old 06-30-2006, 01:29 AM   #12
Car: WRB 05 STI
good info guys.. makes me want to buy it..
Bolshoi125 is offline   Reply With Quote
Old 06-30-2006, 03:14 AM   #13
Car: '05 Aspen STi
Fav Mod: Wingless
Nice write-up. I'm sure the effort to take the pictures will be appreciated by many members who are on the fence about this product.
Nis01 is offline   Reply With Quote
Old 06-30-2006, 10:52 AM   #14
Car: 2008 STi
Send a message via AIM to its reneeee
i brought my laptop into the garage a couple days ago and followed these steps when i installed my AP. it was so easy i felt like i was doing something wrong
its reneeee is offline   Reply With Quote
Old 06-30-2006, 11:02 AM   #15
Car: 06 STI
I'm glad it helped you out!
I need to resize the picture but I'm so lazy ..
