Old 05-16-2007, 06:40 AM   #31
Car: 2004 STI PSM
Default Re: How to - Plug and Play with the AccessPORT
Thanks for the info.
sti04dude is offline   Reply With Quote
Old 05-19-2007, 11:02 AM   #32
Car: 2006 WRX STI
Send a message via AIM to altima04
i got a question, how do i get it back to the stock ecu?
altima04 is offline   Reply With Quote
Old 05-19-2007, 12:59 PM   #33
Car: 07 WRX STi Limited
Fav Mod: Trunk Monkey
Unmarry it.
JiveMasterT is offline   Reply With Quote
Old 06-13-2007, 04:50 AM   #34
wow this is a great thread that has answered a lot of my questions. I have one too about the AP. I know people buy used ones all the time but how do you know if your AP has been properly unmarried? Will you not get that screen on the AP display like those shown on post#1 on this thread? Thanks for any help. I'm a noob too btw.
wanalaugh74 is offline   Reply With Quote
Old 06-15-2007, 12:13 PM   #35
Car: 06 STi
Fav Mod: Wing delete
Default Re: Follow-Up...
Originally Posted by sti04dude
Cobb will not guarranty that their catted downpipe will pass emissions testing.
That was rather disappointing to hear, as it is a major reason to install a catted downpipe.
Thanks.
Even heavy-duty cats cannot compensate for an engine that's running out of tune. A cat has a narrow operating range; and overly rich or overly lean mixtures will cause either too much CO and HCs, or too much NOx (respectively) for the catalyst to deal with. On a different note, really off ignition timing, atmospheric BOVs, or running plugs that are too cold, can all damage the cat.
Bottom line: nobody can guarantee a cat, unless you can guarantee it was tuned to manufacturer's specs. With a tuner part like they just can't do it.
Supermarkus is totally right.
Re federal law: You cannot ever remove functioning emission control equipment, except to test it. You cannot replace non-functioning emission control equipment with aftermarket parts within the first 2 years -- it must be OE. Furthermore, the OE stuff is warrantied for 8 years or 80,000 miles on all cars model year 1995 and newer.
Sans-nom is offline   Reply With Quote
Old 08-03-2007, 06:57 AM   #36
Going back to the AP and the Green connectors...
For an 07 STi, will I be looking for them at the steering column or on the Pass. side kick panel or both?
Best access to the conenctors at the steering column? (I'd assume from below, w/o removing the panel.)
Which should be connected?
Which should be disco'd after reflash?
Anything else I should know before I do this later today? Thanks in advance!
Old 08-03-2007, 09:57 AM   #37
There is a set of green connectors under the dashboard AND behind the plastic on the passenger side. If you plug in the green connectors under the dash and the car does not go into debug mode then you need to check the ones on the passenger side. Usually the dealer will just unplug the ones under the dash for simplicity sake, but sometimes they go the extra mile and unplug the ones on the passenger side.
The plastic I'm talking about is the part that covers the passenger side door sill. It just pops off.
Old 08-03-2007, 12:23 PM   #38
Done, that was easy. Took a while to upload, but it's flashed and running sweet!
Thanks for the help!
Old 09-04-2007, 11:21 AM   #39
i eat cones
Fav Mod: catless
awesome write-up, going to flash stage one when i get home its waiting on my door step
thanks dragon
Szumita is online now   Reply With Quote
Old 04-27-2008, 06:18 PM   #40
Car: Black 08 STi
If you go to the cobb website they have a great video of how to install the newer AP
SlackerNJ is offline   Reply With Quote
Old 04-27-2008, 10:06 PM   #41
Car: 06 Subaru WRX STi
Fav Mod: The Hooptie
Send a message via MSN to jungo75 Send a message via Yahoo to jungo75
Or just read the darn manual
jungo75 is offline   Reply With Quote
